8th August 2012
Ride That F'N Sportster!!
Posts: 12,088 Sportster/Buell Model: Highly modified 1200 c Sportster/Buell Year: 01 Other Motorcycle Model: FLHX H-D Street glide Other Motorcycle Year: 2013
Originally Posted by norseXL
Back when I had the Hydra-glide, last thing I needed was trying to find neutral before kicking the thing.
Also I have been known to yell at anyone who leave a bike at the work-shop floor in gear.
One thing pushin bikes away if not have to fiddle with the gear lever to, do that 20 times a day and you can be a little grumpy.
Bikes just don´t roll away on just a little incline! But hey do whatever you want, exept on my floor
Good Point!
I've raced AMA dirt-bikes for yrs, you never try to kick start a hot bike in gear, specially the new 4 strokes, as it will catch you off guard if your NOT ready for it...the Sporty is the same way..i've seen more noob clowns hit the start button without covering the clutch or first rocking the bike back and forth outta gear before hitting the fire up button..the look of embarrassment on their face is priceless..
I only put my bike into gear UNLESS it's on a steep! Always have for 3.5 decades of riding!
8th August 2012
Dont know nuthin
Posts: 352 Sportster/Buell Model: 48 Sportster/Buell Year: 2011 Sportster/Buell Model #2: 883 Sportster/Buell Year #2: 2008 Other Motorcycle Model: Suzuki GN125 Other Motorcycle Year: 1997
My basement garage is perfectly flat. Yall do what you want but on my floor if parked with engine off it will be in gear.
8th August 2012
I say the only reason to park your bike in gear is to stop it from rolling off the stand. I've never known my bike to start rolling all by itself on a flat, in the garage or parked in a motel room..
I'd be more worried about it falling over on hot asphalt or sinking in wet grass, but hey crushed beer cans are handy for those moments...
so,
On the flat, neutral.
On a slope, 1st.
Of course it's hard to find any hill at the beaches of NC...
RTFS Ride That F'N Sportster!!
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
8th August 2012
Dont know nuthin
I say the only reason NOT to park it in gear is if your doing some sort of maintenance on it that requires it to be in neutral.
8th August 2012
Why go thru the added motion on a flat?...
Speaking of doing maintenance, right now i'm checking both wheel bearings, still don't put it in gear even going on the bikestand, just gets tied down...
8th August 2012
Dont know nuthin
Whats added? I park I turn it off......it was already in gear.........your the ones adding a step.
8th August 2012
Posts: 511 Sportster/Buell Model: XL883/1200 Sportster/Buell Year: 2004 Sportster/Buell Model #2: 1200 CHOP PROJECT Sportster/Buell Year #2: 1997 Other Motorcycle Model: 1200 CHOP PROJECT #2 Other Motorcycle Year: 1992
I can't believe there's 6 pages with of debate on this thread.
Sent from my DROIDX using Tapatalk 2
8th August 2012
Dont know nuthin
Yeah amazing aint it...........and I contributed a good bit to the insanity
8th August 2012
Posts: 3,476 Sportster/Buell Model: 883 custom Sportster/Buell Year: 2004 Other Motorcycle Model: FLSTF Fatboy Other Motorcycle Year: 1999
I park in neutral unless I'm pointing down hill. If up hill, no problem.
8th August 2012
Posts: 1,290 Sportster/Buell Model: 883C Sportster/Buell Year: 2005
Originally Posted by Jimmy_Hoffa
The manuel says not to shift when the engine isn't running, says it can hurt the tranny. I try to shift to nuetral before shutting down. On accasion I have parked in gear and started it in gear also.
The other day I parked faceing down my driveway and didn't trust the kickstand, so I put it in gear while it wasn't running. Then found nuetral before starting it. I'm gentle with it, I roll it around a little, so I'm not forcing it into gear or anything.
Is that bad for it?
These transmissions are not exactly delicate and Harley's lawyers wrote the manual. I've got one page in mine that 5 different times says "... could result in death or serious injury".
Unless you're coasting downhill and stomp the tranny into first, you're not going to hurt it. Even then you'll probably be OK.
Honest, I don't know either of the women, and the midget was on fire when I got here.
