swanny, Mrs Jimi, SnarleyHarley (63), UtahMark, ihjonny (56), fatchuk (55), provision (47), randreb (47), joeyhunter (44), junk runner jr (38), Pegscraper05 (35), cowboy_hamilton1@yahoo.co (34), wi1dwood (34) |
25th June 2009
Posts: 280 Sportster/Buell Model: 82 xls 1000 Sportster/Buell Year: 1982
I just watched the you tube tappet adjusting video, and think that is something I can do.
What about setting the timing, I have electronic ignition, how would I go about that, or is it better to have a shop do that.
http://picasaweb.google.com/dan.maltby/BackFromRebuild#5388709149769213666
82 xls Roadster/Andrews PB+ Cams/S&S Super E / drag pipes/ 2"baffles/exhaust wrap
None are more hopelessly enslaved than those who falsely believe they are free!
25th June 2009
Posts: 23,702 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
It is best to do both of these yourself.
Go to the top of this forum, the red threads just after the announcements. Find this one:
Sticky: Ironhead Technical Stickys Index - TuneUps, ReBuilds, Etc, Etc, Etc
In there you will find just about everything that you need on pushrod adjustment, ignition timing, and much much more.
25th June 2009
Posts: 1,142 Sportster/Buell Model: XLH Sportster Sportster/Buell Year: 1991 Other Motorcycle Model: 650 Triumph Bonneville Other Motorcycle Year: 1970
Take a wooden stick and move it around the engine at different R.P.M.'s with your ear against the other end.
normally the rod or wrist pin will be a double knock. and gets louder as the rev's go up.
sweep your oil tank with a magnet and cut your filer apart. look for metal. that's if it sounds like major problems.
883 / 1200 conversion, shrink ported high velocity heads, milled .020 off the compression side. stainless steel tulip conversion valves. 10:1 wiseco forged pistons. "W" cams, Crane HI-4E ignition module, forcewinder AC. mustang seat, Progressive springs, RK-shocks, fork brace. metzeler me880 tires, headlight modulator. PIAA intense white H4 bulb
26th June 2009
I did cut the filter appart and looked inside. I saw between the the carboard some metal. Not a whole lot, but there were some fine shavings and metal dust. You kind of had to look real close but I could see some metal. Is that normal
8th August 2012
Posts: 25 Sportster/Buell Model: Sportster Sportster/Buell Year: 1976 Sportster/Buell Model #2: 1976 Ironhead Sportster/Buell Year #2: 1976
Was riding last night , and made a left turn and it was like someone threw a switch. Bang, then a vavle tap sort of sound. Never had any sounds like this befor efrom this motor.( 1976 Ironhead ). Now I have a constant valve tap type of noise. Any ideas?. I'm running 20 w 50 Valvoline 4 stoke V twin motorcycle oil. I change every season, including the filter. Oil level was fine when I set out on my ride last night. Even with the noise the bike still runs great. But i need to fix this.. Any help would be great
8th August 2012
Posts: 510 Sportster/Buell Model: XLCH Sportster/Buell Year: 1973 Sportster/Buell Model #2: 1981 XL Other Motorcycle Model: Norton HighRider Other Motorcycle Year: 1972
Chris B- what octane booster are you using?
The type sold at auto stores, states that a can added to 18-20 gals of gas, raises the octane level 1-2 points.
so 1-2 capfuls in 3-5 gals of gas, does very little insofar as rasing octane levels to any meaningful point.
Do you have a brand that rasies octane levels higher than that? If so, I'd like ot try it.
9th August 2012
Originally Posted by Richprint
Was riding last night , and made a left turn and it was like someone threw a switch. Bang, then a vavle tap sort of sound ...
I would adjust the pushrods ...
Ironhead Push Rod Adjustment
http://xlforum.net/vbportal/forums/s...ad.php?t=44143
9th August 2012
Banned
Posts: 1,613 Sportster/Buell Model: XLH Sportster/Buell Year: 1976
The whole bike vibrates, my wires vibrate against stuff and make tapping sounds... . it doesn't stop making sounds until I turn it off. I love it :F
14th August 2012
Posts: 8 Sportster/Buell Model: xlh1000 Sportster/Buell Year: 1979
engine noise
I recently experienced similar problem- Drove me nuts- Ended up being a bad valve guide-You would not believe how wore that guide was- Dont know why only one but it ran beautifully so it was by accident I found it . Put new guide in first- it ran quiet then did all - Good luck
