10th August 2012
Posts: 9 Sportster/Buell Model: Sportster XL 1200 Custom Sportster/Buell Year: 1998
Handlebar dilemma!
Hey guys,
Hoping someone can help me with my handle bar predicament...
I'm 5'10 & 190lbs so an average size person looking to maintain comfort while I ride but would like to dress the bike up a bit. Looking to get some narrow ape hangers for my 1998 Sportster XL 1200 Custom (its a work in prgoress). I'm told by the HD dealer that all the wiring is tucked into the stock 5" riser so eleminating it is an incredibly coslty option. If this is the case i'm left with the option of shorter ape hangers (10"-12") and found a few options from either HCC, Burly, and Wild 1 Outlawz.
I know its a preference thing but hoping that someone can provide some input having the same bike. Did you change the riser? Do you have the 12" bars (with stock riser) and are they comfortable?....etc.
Eventually I want to do a lowering kit as well as a fat tire kit, may also rake forward a bit....it never ends...lol
if you check out August '12 bike of the month on the Burly site that's exactly what my bike would look like but not sure what size ape's those are and if those could in any way be comfortable. I also saw a set of mini Apes (10") from Wild 1 Outlawz. Couple great pics in the gallery here also.
I'm Lost!!!
Your input is appreciated and thanks again,
Mr. Bones
10th August 2012
Posts: 2,875 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2002
If you get rid of the riser all you have to do is put the connections under the tank and extend the wires to the lengh you need them to beif you want to keep the ability to unplug them in the future if needed. If not cut the wires under the connectors and extend them. Harley actually sells an extension kit for the wires. Solder them dont crimp the connections and if you plan to run the wires internally dont cut and solder them all in the same place. Make each cut and solder joint about a half inch to an inch apart so the wires wont be to thick to run through the bars. I dont have any experience with apes
2002 XL1200C (originally)
Stage II Buel XB Heads, Andrews N4 Cams, Mikuni HSR42 Carb, Forcewinder Air Filter with Float bowl vent mod, S&S Roller Rockers, Jim's Powerglide Lifters, Thunderheader Exhaust, Daytona Twin Tech SIngle Fire Ignition, Crankvents.
Max Power=85.47
Max Torque=81.84
Flow Bench Results
10th August 2012
Ride That F'N Sportster!!
Posts: 12,058 Sportster/Buell Model: Highly modified 1200 c Sportster/Buell Year: 01 Other Motorcycle Model: FLHX H-D Street glide Other Motorcycle Year: 2013
Correct, ditched the ugly custom riser yrs ago..ended up hard wiring them directly myself, just labeled each side before making any cuts, should be 5 wires per side, put all joints by hiding the wires inside the handlebars and under the new MG triple trees..doesen't have to cost an arm and leg to do this conversion, just takes patience and a little mechanical ability to do it on your own, and knowing you did it yourself without getting raped by the local $tealership and their bullshit pricing!
10th August 2012
Posts: 13,143 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
11th August 2012
Thanks for the great feedback guys! I think I'm going totally this project myself. Screw the dealer and their bull$h!t pricing.
Does anyone know if you can just flip the speedo around to the headlight side?
11th August 2012
Posts: 895 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2009 Sportster/Buell Model #2: XL1200L Sportster/Buell Year #2: 2009
For options to relocate your speedo, find the "Xena Mod" using the search at the bottom of the page. You'll find a few other ideas, in here also, if you dig a bit. The angle of the speedo bracket itself will be the determining factor. You may need to find one that's made for that location, because of the way it's bent, or the way the speedo & idiot lights mount to it. Once you take it off & see how that stuff is assembled, you'll see what you need to do. Take your time, think about it & have fun.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
I didn't buy a Sportster 'cause I wanted a Harley... I got a Harley 'cause I wanted a SPORTSTER!!! He who gives up liberty for security, will have neither. Ben Franklin
11th August 2012
Not back 10 yrs ago,
the custom model speedo is specific to that particular model...been there done that, my OEM speedo sits in a box on the shelf cause it useless other than in stock configuration, thus the reason for the Dakota Digital speedo...
Fast foward..
Check J&P cycles, Dennis Kirk...etc
They do carry replacement cups so the speedo can be turned around to mount foward of the handlebars, it needs to be 3.5" center to center to mount on a custom model with new risers mounted without having the eyebrow (Xena
mod) on a custom model..
Also apes can be fitted to the OEM custom riser, but IMHO if your going to do the whole mod get some new risers and dump the stock ugly riser to help clean up the look of the front-end
11th August 2012
Posts: 15,373 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
Harley will charge you an arm and a leg because its a time consuming job but, not a difficult one. I think the going rate just for the wiring of the handlebars and installation goes for about 400 bucks labor.
Do it yourself over a weekend and save yourself a bundle. And you'll know that its done right. Harley labor leaves a lot to be desired.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
15th August 2012
Thanks for all of the input guys...decided to eliminate the stock riser and go with 14" apes with a 1.5" riser. Now the question is which black apes do I get. I like the look of the wild 1 narrow Outlawz, but would like something that fans out a bit more. Any suggestions? Also has anyone switched out their tank for a fatbob style tanks?
15th August 2012
Here is one thread about them. there are others who have done it also.
http://xlforum.net/vbportal/forums/s....php?t=1523154
