23rd July 2012
Posts: 1,543 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
I would suggest longer fork tubes. Fork extender can bring fitting, adjustment and structural problem.
24th July 2012
OzChick
Posts: 2,324 Sportster/Buell Model: XL 1200N Sportster/Buell Year: 08 Other Motorcycle Model: Trumpy
You can "extend" the fork by changing out the internal damper rods. That (and fork springs/preload) is the key difference between the Iron's front suspension and the R for instance. Seraphan6 has a thread that shows that the stock fork tubes are the same length between the various rubbermount models (particularly the R and the N in that thread) and that changing the travel in the front forks is dictated by the length of the damper rod. As far as I know there are at least three different length damper rods: the 1200R/883R/1200C/833C share the one that gives the most travel; the 1200L in between; and the 1200N/883N/883L have the shortest.
I *think* Nitro went with the 1200L damper rod in his build.
OzChick ~ Riding Nyx
Only a biker knows why a dog sticks its head out the car window...
My Photos: www.photobytrace.com
24th July 2012
Posts: 1,017 Sportster/Buell Model: Sportster XL883N Sportster/Buell Year: 2009 Other Motorcycle Model: CBR replica minibike
Thanks for jumping in Trace.
She's right, you just need damper rods from an R or C model. All the fork tubes/sliders are the same. I went from N to L and am now using R damper rods with RaceTech springs. The Ls give you an extra 3/4", the R/Cs give you 2".
If you want to keep using the gaitors they'll work with L length but will leave a gap with the R/Cs. I cut up a couple of pairs of HD gaitors and superglued them together - no issues after a year or so. Or there are cheap aftermarket ones that will do the same.
"When I was a kid I used to pray every night for a new bike. Then I realised God doesn’t work that way, so I stole one and prayed for forgiveness."
24th July 2012
I did but now have Rs with straight rate springs and Intiminators - brilliant package - if you've got the legs!
24th July 2012
Posts: 69 Sportster/Buell Model: 883 Sportster Custom Sportster/Buell Year: 2005
That's what she said
24th July 2012
OzChick
 Yeah I bet!!! And of course, I wish!
When I re-read your post after I replied I took in the 2" increase and kind of figured you may have changed out to the longer damper while I wasn't paying attention.
I've been thinking about my forks again lately and am getting "needy" for that R damper. Think that will be this summer's project while the monsoons happen. After riding Dan's 1200R last year with the stock setup I WANT that travel and while I know I'll have to be careful, I also know my tiptoes do reach
Though needless to say I won't be going 14.25" on the back
11th August 2012
Posts: 443 Sportster/Buell Model: 1200N Sportster/Buell Year: 2009
Originally Posted by Doc Pirahna
I just put 15"s on my Nightster. The bottom of the shock could rub the exhaust if you have a stock one. I just banged a dent on the inside of mine. The belt is apparently rubbing on a part of the muffler interconnect near the front sprocket. I might be able to mitigate this with some adjustment however. I am still running the stock kick stand as well.
Doc, did you do anything to remedy your belt rubbing the muffler support? I'm noticing the same thing on mine after lifting the back end up with the hybrid shocks. I was thinking of grinding out a notch in the support bracket so the belt doesn't touch it, but I'm not sure it is a good idea because I don't want to compromise the structural integrity of the bracket.
Dyna bottom mount headlight, RSD Clip Ons, NRHS Hurricane 2" A/C, Hand made Lucite A/C Cover, Screamin' Eagle II Slip ons with BCT Monster Baffles fitted, Whittle Beast Hybrid Shocks-Using the HD 2 up low profile springs, Engine Tuning by me and my TTS.
18th August 2012
I wanted 15" shocks, but 14.25" is the longest you can go before the belt touches the rear brake bell housing.
Correction, you can run 15" shocks with stock exhaust/slipons. You just gotta space out the crossover pipe bracket, the rear brake bell housing is fine and it stops the belt rubbing. Don't ask, but I broke two exhaust screws finding this out...
29th August 2012
Posts: 29 Sportster/Buell Model: 48 Sportster/Buell Year: 2012
Whats the cheapest Online store to pick up Progressive shocks?
30th August 2012
What do you mean by space out?
