The Sportster and Buell Motorcycle Forum Sportster Specialty
Speedway Instruments
NRHS Performance Long 2
Ricor Shocks
Old 21st August 2012
hogmania hogmania is offline
hogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura about
on my 80 with a 34mm carb I'm running a 65 with a 165 main, tried a larger pilot jet and it was doing the same as yours is.
Megadeth's Avatar
Megadeth Megadeth is offline
Sportster/Buell Model: Sportster 1000
Sportster/Buell Year: 81
Megadeth is on a distinguished roadMegadeth is on a distinguished road
With the 65 pilot i had to turn mixture out all the way.
Sent from my M865 using Tapatalk 2
jhaines's Avatar
jhaines jhaines is offline
jhaines is an unknown quantity at this point
I've got a 75 in mine. With that I set my pilot screw at between 3/4 and 7/8. If you turn it more than a full turn out you need a bigger slow jet. 75 is what works in mine.
I'm just a newb with an ironhead, a toolbox, a computer and a FSM.
Megadeth's Avatar
I put a 75 in last night and mix was 2 1/4 out. Thats why i went with 80 sounded good at 3/4 out. But think i cooked plugs. When i get home from work going to slap in new plugs and hop on and see what hsppens. Cant believe how hard this has been to jet., what main are running?
jhaines's Avatar
165 in the main
IronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud of
I put a 75 in last night and mix was 2 1/4 out. ...
If that is a 34mm Keihin carb then something is wrong, or your pilot setting technique is incorrect. Have you dismantled/cleaned/inspected the carb? Post some pics of the carb [top, front, sides] so we can verify what it is. Measure the venturi at its most narrow point - cut two pieces of cereal box cardboard one 34mm the other 38mm and see which fits best.
Note that you cannot set the pilot screw by running the bike in a shop. You really do have to run it out on a quiet hiway for at least 20 minutes, then set it while the engine is fully warmed up. I set it approximately in the shop then do a final setting at the side of the road.
Megadeth's Avatar
It might be how i a doing it.what size pilot and main should i be using with drag pipes and high flow a/c. I cleaned carb and did rebuild kit. It is a 34mm checked it last night. Had stock jets when i got it and mixture turned almost all the way out. This is driving me crazy. Got a big ride coming up would love to have it ready to ride.. Thanks everyone for all your help
Megadeth's Avatar
I did try and do it in shop . Took it for short ride to warm up then back in garage to adjust
Stock jets for 1981 are main 160, slow 68. I would guess that main 170; and slow 75, maybe 80.
Megadeth's Avatar
Got 170 main 80 slow now. When you say you tune it on road do you just pull over adjust mixture and idle. Then ride a little more till right?
