20th August 2012
Posts: 4,296 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006
Why waste you're money? Do it right the first time.
Getting through the Break-In Miles Sucks!
20th August 2012
Posts: 1,535 Sportster/Buell Model: nightster Sportster/Buell Year: 2007
couldnt agree more..learned the first time there wont be a second..
21st August 2012
Posts: 289 Sportster/Buell Model: 883 converted to 1212 Sportster/Buell Year: 1993
Alright I will do it your way :-)
21st August 2012
Posts: 216 Sportster/Buell Model: XL1200 Sportster/Buell Year: 1998 Other Motorcycle Model: Harley Davidson FLH Other Motorcycle Year: 1973
Hmmm...you should do what's right for your situation, but the Colony kits are not junk. The heads have good depth and are pretty good at resisting rounding off. As was pointed out in an earlier post, stainless steel has its own issues, and is not necessarily stronger in a given situation. If you need new primary bolts, the chromed carbon steel approach is not a bad choice (and, at nearly $2.00 a bolt, even on ebay, not all that cheap, either). Just my opinion, Good luck with your choice.
Joe
Taxes paid- SE II slip-ons & S&S A/C, CV rejet
Dyna front caliper & full-floated disk
Forty-eight bars with black powder coated risers
Corbin-Gentry 1957 XLCH replica solo seat
HD forward controls, 11-1/2" Progressive rear shocks
Manual petcock that doesn't suck
"An armed society is a polite society." Robert Heinlein
21st August 2012
Brass Nut
Posts: 30,434 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
Originally Posted by morvenhouse
I've used their brass dome nuts; only place in the UK I've found for them in unified threads.
Folkie
'The green machine'
22nd August 2012
Posts: 520 Sportster/Buell Model: XLH1200c Sportster/Buell Year: 2002
Ace hardware carries chrome nuts/bolts/washers, they keep them locked up though!!
I needed some chrome washers for a project on my Sporty, cheaper than the dealer.
22nd August 2012
outside the box racing
Posts: 4,339 Sportster/Buell Model: Turbo 1350 XLSR Sportster/Buell Year: 99 Sportster/Buell Model #2: Turbo 1350 XLDS project Sportster/Buell Year #2: 2000 Other Motorcycle Model: 883->1330 dragster Other Motorcycle Year: 1991
i get all my stainless from McFadden-Dale Industrial Hardware Supply at an amazingly low price.
primary is easy, there are only 3 size bolts and they are common.
don't buy kits - they are all ripoffs. oh yeah, don't go to Ace or similar for same reason.
