Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Drivetrain > Sportster Motorcycle Tires, Wheels, and Brakes
Get Lowered
NRHS Performance Long 2
Marks Moto Gear
Old 1st August 2012
curtisvitoria curtisvitoria is offline
Sportster/Buell Model: 1200 XLC
curtisvitoria is an unknown quantity at this point
Default 21 inch rear rim Anyone done this?
On the fence between a hardtail of flatracker. I am leaning toward the flatracker look and wanting to mount a double star 21" rim on the rear. I have a 2001 xlc and took some measurements looks like the rim should clear. I would like to know the stock axle size and which rim would work? I think I could pull it off without extending the swingarm .Thanks for your help. Curtis
Any pics of this done would be great!
Old 4th August 2012
tmack-1's Avatar
tmack-1 tmack-1 is offline
Sportster/Buell Model: Sportster XLH1100
Sportster/Buell Year: 1986
Other Motorcycle Model: Rupp Roadster
Other Motorcycle Year: 1971
tmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nice
Remember when taking measurements of the swing arm clearances to add some for tire expansion at speed. Centrifugal forces make the tire get a bigger circumference.
While laid off I worked on a Ninja 750. The kid that owned it put a bigger rear tire on. It had a good inch of clearence, but the tire still burned thru the plastic fender. Took some explaining to get the kid to understand.
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
Old 5th August 2012
ron521's Avatar
ron521 ron521 is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 1991
ron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really niceron521 is just really nice
I've seen it on other Harley's but never yet on a Sportster. A wheel that tall will raise your seat height unless you make other changes.
My old Vincent had a 19 on the back, and a 20 on the front, as the designers believed that more or less equal sized wheels (the rear tire was slightly wider) gave better handling.
A machine's form is a product of it's function, and what WORKS best IS best.
Old 8th August 2012
ESS ESS is offline
ESS is an unknown quantity at this point
http://www.hotbikeweb.com/features/1...1/viewall.html
And 23"
http://www.hotbikeweb.com/features/1...r/viewall.html
http://www.lightningrodmotorcycles.com/Trackster.html
Looks like they have extended swingarms though.
Old 8th August 2012
rabidchimp rabidchimp is offline
Sportster/Buell Year: 97
rabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enough
I really dig the look with the 21s out front and back.
-Aaron
Stairman for President 2012, 2016, 2020 etc.
