5th July 2012
Posts: 5 Sportster/Buell Model: m2 cyclone Sportster/Buell Year: 2000
m2 jetting?
i just bought a 2000 m2 with a k&n carbon fiber intake. the bike also has an unknown after market muffler that was cracked and re-welded by previous owner who said most of the packing was lost. anyways the bike runs decent but i checked the jet sizes which are 200 and 42 with the mixture screw still capped. does this sound right or should they be changed? previous owner got the bike this way "besides for muffler cracking and loosing packing" and rode this way for 7 years and 14k miles so it must be ok but could it be better?
5th July 2012
A Million Facts & Figures
Posts: 5,899 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
slug, it's really hard to jet a guy's bike by internet, all any of us can do is give guidelines. You really have to put it on a dyno, preferably one equipped with an air/fuel sniffer, to evaluate your jetting.
That said, I've personally found more success with a smaller main jet than that, more on the order of a 185, along with a 45 pilot and around 2-1/2 to 3 turns out on the mixture screw. In other words, fatten it lower and lean it higher. The stock needle should be an NOKK if memory serves and that's a good needle, I wouldn't worry about it.
But if you make any changes like this, take steps to verify it. Plug readings are kind of difficult on today's pump gas because they burn so clean, but do take a look. Really, like a said, a dyno with a sniffer is the best method.
29th July 2012
Posts: 80 Sportster/Buell Model: XLX Sportster/Buell Year: 1983 Sportster/Buell Model #2: M2 Sportster/Buell Year #2: 2000 Other Motorcycle Model: FXDWG - FLTR Other Motorcycle Year: 99
I opened up my 2000 M2 today and it had a 200 and 42 and NOKK. I am pretty sure it was stock jets and needle. I got pinging when WOT and hot so I bumped it up to 205 and 45 and tried a NOKG. I have a Forcewinder and a Supertrap muffler... I'll see how it rides this week and go from there...
30th July 2012
Have you done the mod to your Forcewinder to make it work with the CV?
It's very, very critical too do this, if you value your engine.
Here's a thread I created about it back in 2002:
http://www.badweatherbikers.com/buel...tml?1233360082
30th July 2012
Thanks. Do you make it any deeper or just wider?
30th July 2012
Much deeper and wider both
31st July 2012
I gave it a shot with the dremel tool... this what I am going for?
31st July 2012
Close to it, there should be a boss cast into the outside that acts as a pretty good guide for the depth. I see you have quite the little assistant there!
31st July 2012
Yeah, he is handy...
| Thread Tools |
| Display Modes |
