The Sportster and Buell Motorcycle Forum Licks Tanklift
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Seating and Luggage
NRHS
Figure Machine
Figure Machine
Old 2nd November 2012
Scar55 Scar55 is offline
Sportster/Buell Model: 1981 xlch
Sportster/Buell Year: 1981
Other Motorcycle Model: Night Train
Other Motorcycle Year: 2007
Scar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to allScar55 is a name known to all
I think you better look into this alittle closer. I just put a factory solo seat from a 2011 or 2012 model on my 06 custom. The 06 seat has an indintion in the seat pan to clear the electronics box that is under the seat. The newer seat does'nt have this indention. I also had to modify the rear bracket to make it line up the the mounting hole in the rear fender. I just used a cut off wheel on the seat pan and cut out the plastic to clear the eletronic box.
Folkie Folkie is offline
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
Thank you for providing that information.
How stupid of H-D not to make the seat backwards compatible.
'The green machine'
On the other hand, the Metal Flake solo seat, which is just the stock '72' seat with a metal flake covering, say it does fit the '04 - '06s:
(clicky)
Metal Flake Solo Seat
Add a little sparkle to your ride with this custom Metal Flake solo seat. With a nod to the choppers and bobbers of the '60s and '70s, this minimalistic seat features a brilliant high-gloss metal flake vinyl seating surface that is finished in the classic diamond checked upholstery pattern. The look will stop traffic, and will certainly make your ride stand out in a crowd.
52000051
Fits '04-'06 XL, '10-later XL models with 2.2 or 3.3 gallon fuel tank. Seat width 10".
Silver Charcoal
MSRP US $129.95
