Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Engine Conversions
cbsportster (67), sjeccles (50), 2011_Nightster (50), reeb (47), Maff (47), jl_rotary (40), UMLsilva (32)
  #41
Old 22nd September 2017
Sportster/Buell Year: 1988
Four Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant futureFour Speed has a brilliant future
Sounds like you have plenty of oil pressure! I have the upgraded oil tank where the oil return is at the bottom of the tank rather than half way up, so I don't have that issue. What oil pump did you end up using Duker?
cycowrencher's Avatar
How do you block off the bypass? I just replaced the spring and ball, but still feel the flow is low at idle (i idle at 1150 to 1200rpm)
WI_duker's Avatar
WI_duker WI_duker is offline
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
Used a 2 inch spring. It's never going to open
It's Hammer time
WI_duker's Avatar
For now the stock.
rocketmangb's Avatar
Default Bypass
You cant.
Late 5 speeds dont have a bypass,I think starting in '92
The spring and ball are really just a check valve that opens at around 6 PSI and also serves as an anti-drainback.
Have you up-dated the oil pump ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Mikuni HSR 45 /Hammer Billet Manifold
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
You cant.
Yes. It has a brand new buell pump in it.
Unless you can find a Pro Flow pump you did all you can do !
Might try some different oil filters ?
shanneba shanneba is offline
You cant.
Except the XR1200Xs, they have an oil bypass that opens at 50 psi.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Whole different animal !
WI_duker's Avatar
You cant.
I'm going to update the pump this winter to the 07 buell.
As to the bypass it opened on me due to a week spring.
When it does that you have 0 oil pressure and you roast your engine. The oil light will never come on either.
You may be confused. The 86-90 has a separate bypass in the oil filter mount. That's what I blocked
