famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27) |
8th August 2012
Posts: 22 Sportster/Buell Model: Sportster 1200 Sportster/Buell Year: 1992
Blow by from breather
Im wondering what the best way is to run my breather from my intake , right now it drips oil on the engine
8th August 2012
Known Troublemaker !
Posts: 7,347 Sportster/Buell Model: Sportster 1200C Sportster/Buell Year: 06
There are many options for that problem and it is a pretty normal question around here. You couls replace the factory Air cleaner assy with something that flows better and has provisions for rerouting the blowby gases. Usually to the ground.
There are a few mods that can be done to the factory air cleaner as well. If you do a search on here you will find dozens and dozens of threads on this..
BYW Use the search function at the bottom of the screen, it works best..
8th August 2012
Posts: 4,669 Sportster/Buell Model: Hammer 1250 Hugger Sportster/Buell Year: 1997
J&P sells a couple nice breather set-ups that allow you to remote mount a breather filter away from the air cleaner area down behind the engine.
Support the forum because the
George
"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
| Thread Tools |
| Display Modes |
