11th June 2012
Posts: 129 Sportster/Buell Model: sportster Sportster/Buell Year: 1975
cv carb missing part question
hey guys, getting ready to wrap my ironhead boardtracker project up and started cleaning the cv carb prepping for install (don't know what year the carb is off of, it was on the bike when i got it). i don't know if i lost a part or it didn't come with it to be honest but today i noticed that part # 38 in the diagram below is missing. i remember the bike idled and accelerated fine before i broke it down. can i buy this piece somewhere? or do i have to make something like a washer to hold the needle down? not sure what to do. thanks, Lou
11th June 2012
Posts: 8,658 Sportster/Buell Model: XL1200 R Sportster/Buell Year: 2006
It looks to me the purpose of part # 38 is to keep the spring centered and possibly to keep the needle seated against the slide. Both are important.
Ricor test rider for IAS Shocks, Intiminators and Vibranators. Works Dual Rate fork springs, fork brace, Avon Venom X tires, loosen drive belt, and set frame rails level to floor. Read the "7 Pages of Suspension" thread in the Suspension Sticky Index to learn how to fix your suspension.
11th June 2012
Posts: 985 Sportster/Buell Model: xlh 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: XLCH 1000 Sportster/Buell Year #2: 1979
It's a plastic part, holds the needle down in the plunger and centers the spring. had one in my hands a couple weeks ago.
11th June 2012
Posts: 572 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2004
It is the following part number available from HD, and yes you certainly do need one.
SPRING SEAT - Part No: 27586-88
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
11th June 2012
Posts: 2,535 Sportster/Buell Model: chopper looking thing Sportster/Buell Year: 1978 Other Motorcycle Model: Triumph POS Other Motorcycle Year: 1972
+1 It's a fluke that the carb worked without it.
11th June 2012
thanks guys i'll be checking it out at the harley dealership!
11th June 2012
Posts: 1,561 Sportster/Buell Model: XLH Sportster/Buell Year: '78 Sportster/Buell Model #2: 883 XLH w/1200kit Sportster/Buell Year #2: 1993 Other Motorcycle Model: 93" Pan/Shovel Other Motorcycle Year: 1968
If they don't have one, or it's "obsolete", let me know. I've got a few laying around.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
| Thread Tools |
| Display Modes |
