Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Licks Cycles
Get Lowered
Get Lowered
Zippers Performance
CV Performance
Old 30th July 2012
squekster's Avatar
squekster squekster is offline
Sportster/Buell Model: 883/1200 conversion
squekster will become famous soon enoughsquekster will become famous soon enoughsquekster will become famous soon enoughsquekster will become famous soon enoughsquekster will become famous soon enoughsquekster will become famous soon enoughsquekster will become famous soon enoughsquekster will become famous soon enough
Default voes adjustment
Can the voes be adjusted on a 2004? It is mounted on the intake.
Old 30th July 2012
NRHS Sales's Avatar
Sportster/Buell Model: 07 883 X2 plus 5 Buells
Sportster/Buell Model #2: 92
Sportster/Buell Year #2: 96
Other Motorcycle Model: and 2 more!!
NRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud ofNRHS Sales has much to be proud of
You do not have a VOES. You have a MAP sensor. To adjust it you would have to use a custom ignititon module like a twin tech and software programmming.
Dan
NRHS
303-702-1600
www.nrhsperformance.com
The truth is out there. It's only a matter of time!
Old 31st July 2012
squekster's Avatar
Thanks for clearing that up. Are the map sensors the same on 883's and 1200's?
Old 31st July 2012
NRHS Sales's Avatar
yes they are but your ignition module is programmed differently from the factory. A twin tech ignition with download kit so you can do custom maps would be what you would want if you need to make changes. NRHS sells both if needed.
