21st February 2012
Posts: 23 Sportster/Buell Model: XL 883 Sportster/Buell Year: 2006 Other Motorcycle Model: Suzuki VL 1500 LC Other Motorcycle Year: 1998
Need an advice (bottom mount headlight)
Hi everyone!
I am slowly rebuilding my sportster and got a few problems.
first - bottom mount headlight. At first I just wanted to use stock headlight case, but I don't see a way to fix it to lower triple tree steady and simple.
second - solo seat. I like that hardass slim seats on springs and want to make one, but I never did such things before - maybe someone have some scetches or drawings of their DIY seat and mount? ebay ones is looking great, still I prefer to make stuff like that by myself (at least it is a good way to get some expirience).
and last one thing - Harley rear turn signals to stop/running lights conversion kit - did anyone used it? is it worth it?
thanks and sorry for my poor english.
22nd February 2012
Posts: 272 Sportster/Buell Model: 883xl Sportster/Buell Year: 06
i believe with the stock headlight you can remove the brow and post it upside down onto the triple tree, i have not done so, as i have been looking into it myself.
the seat pan be scored off ebay, then you can build around that. i personally like rich phillips and his line of spring seats, so i went that route.
i dont use those turn signals, i have the small bullet and they are not running lights only turn signals.
22nd February 2012
Thanks for advice! Yeah, I am planning to just turn the headlight upside down, still I haven't foud a good way to install it - triple tree have too curved profile to simply drill it, and I am afraid to lower it strengh by doing so.
22nd February 2012
apparently my friend drilling a hole in the bottom triple tree is a common practice from what i gathered here. Many people will agree that drilling a hole will not compromise the strength of the lower triple tree. i have seen many mounts on various catalogues but you still need that hole in the lower tree.
anyone chime in and correct me if im wrong.
i read that drilling a hole with a slight angle will stabilize the mount and point the headlight straight, again i could be sadly mistaken.
23rd February 2012
Posts: 815 Sportster/Buell Model: XL1200L Sportster/Buell Year: 2006
you can get a nice cheap chrome headlight made to bottom mount, looks nicer IMHO
23rd February 2012
Ohm's Mafia
Posts: 4,753 Sportster/Buell Model: 1200N Sportster/Buell Year: 2007
A lot of people on here are using the brake/turn/running light module sold by Harley. For $60 it is probably one of their best bargains. However....if you ever plan on going to LEDs on the bike I would recommend getting a unit that is built to handle the LEDs like the Badlands III unit.
Cosmo
14th June 2012
Posts: 1 Sportster/Buell Model: Xl 1200 Sportster/Buell Year: 88
hi alim,
i have the same problem with the bottom mount headlight at the moment. can you report about your solution? (if you have found one)
burn-y
18th June 2012
Posts: 73 Sportster/Buell Model: Sportster 883 Sportster/Buell Year: 1987 Other Motorcycle Model: Triumph Bonny till stolen Other Motorcycle Year: 1971
There are headlight brackets for bottom mount headlights available in the BIG parts catalogs.
You'll need to measure the distance between the cinch bolts on the lower tree in order to select the right bracket.
You may need longer cinch bolts to mount the bracket too.
I want to put on a larger headlight, probably a 7" in a fat steel housing, and it's highly unlikely it would tuck in under the original eyebrow, so I'm sniffing around the same issues.
26th June 2012
Hi, everyone! sorry, I was away from computer for some time
well, there is my first solution:
all measures in mm.
it's a bit complicated, I just wanted to make it looks nicer and smoother, like no sharp angles. I also wanted to hide headlight screw and nut. for the beginning I made a simple bended plate with holes to check sizes, then I was planning to made this mount. Still there is one problem - such installation makes all wiring coming from the bars visible (for now its hidden behind stock headlight brow).
now I am thinking about making new triple trees and risers to hide the wiring and make headlight installation easier. My goal is to get simple and clean look.
| Thread Tools |
| Display Modes |
