Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Progressive Suspension
Get Lowered
Biltwell
Primordial Cycles
  #41
Old 24th June 2012
rocketmangb's Avatar
Jester Mafia
Other Motorcycle Model: 48
rocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant future
It does look funny like I said
Did he put it in from the top instead of above the emulsion tube from the bottom ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
Old 24th June 2012
RustyNuts's Avatar
RustyNuts RustyNuts is offline
Sportster/Buell Model: 883
RustyNuts is on a distinguished roadRustyNuts is on a distinguished road
Yes that was the problem!!!!! I got it fixed 2 days ago at the smoke out! (Felt like a idiot) However I knew it was something stupid!!! The bike runs good and can't thank you guys enough on spending your time to help me fix the rookie mistake!!! Thank you !!!!!!
I always wanted to do TWINS!
Old 24th June 2012
RustyNuts's Avatar
Old 24th June 2012
RustyNuts's Avatar
Old 25th June 2012
PiousDevil's Avatar
PiousDevil PiousDevil is offline
Sportster/Buell Model: 883 sportster
PiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to allPiousDevil is a name known to all
Originally Posted by PiousDevil View Post
When you put the carb back together, you drop the needle in the slide, then the spring retainer on top of that then the spring on top of that, right?
This is the first thing i asked in the first response in the thread? Was i correct?
Everyone in a cage is trying to kill you, best not to make it easy for them.
Old 25th June 2012
Jester Mafia
Pious
The needle jet was in wrong
Old 25th June 2012
PiousDevil's Avatar
Damn it. I'm gonna get one.
