Old 17th November 2009
scottericsonon scottericsonon is offline
Sportster/Buell Year: 1965
scottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enoughscottericsonon will become famous soon enough
Default another minimalistic wiring diagram
well one of the things i'm planning to do to my bike this year is re-wire it...........
theres a couple burned spots in my harness and some P.O repairs that aren't real pretty....
plus i want to clean up that rats nest inside the headlight
so i drew up this little diagram that someone else may also find useful........
i plan to print it out and keep it inside a ziplock baggie in my tool kit "just in case"
Last edited by scottericsonon; 18th November 2009 at 13:40.. Reason: updated drawing
Old 18th November 2009
serengetiotdog's Avatar
serengetiotdog serengetiotdog is offline
Sportster/Buell Year: 1981
serengetiotdog is an unknown quantity at this point
thanks, nice, simple,easy to folllow.
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
you will need a diode in your gen light circuit
24 beers in a carton. ...24 hours in a day . .. coincidence??
where at russ? i hadnt seen one in my manual........
all i saw was one side going to 12V and the other going to the genny
russzx6's Avatar
I think they are in the headlight nest in a stock harness, they are just inline, see post #22 here and pick that part out, you need to make sure the diode is around the right way. What your aiming to do is allow power to flow one way but not back from the battery the other way, the light will glow when it picks up a difference in voltage on both sides of the diode
http://xlforum.net/vbportal/forums/s...=411626&page=3
Fred in WV Fred in WV is offline
Sportster/Buell Model: XLS Roadster
Sportster/Buell Year: 1982
Fred in WV is on a distinguished roadFred in WV is on a distinguished road
The diode should be in the headlight bucket, placed in series with the gen indicator light, or in a wire going from a 12 pin to 6 pin plug, possibly an orange wire. Part #74563-65. Make sure it's taped up good or use a heat shrink.
fixed with the diode...........
should just be a standard 1n-4004
thanx for the heads up
diode isn't shown in my service manual OR my parts book
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
54 to 78 book, page 192, 193
79 to 85 book, page 126, 127
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
i must need new glasses because im STILL not seeing it,,,,,,,,,
ive hilighted all the relevant wires here
IronMick's Avatar
In my 70 to 78 FM it does not show up in the diagrams until 1978. Then it is number 49, left side of diagram, inside the headlite housing dashed line.
