Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Don's Cyclewear
Old 4th January 2011
Jrileydavis's Avatar
Jrileydavis Jrileydavis is offline
Sportster/Buell Model: XL883R
Jrileydavis is an unknown quantity at this point
Default couple questions on my 06 xl883r
Hello all, I'm new to this site as well as owning my sporty. I bought my 06 XL883R about a month ago (my first) and have been ridin the fool out of it!
It has some sort of high flow air cleaner which looks like k&n maybe, and also has a d&d bobcat 2-1 exhaust and a screaming eagle ignition, which were on there when I got it. It only had about 5k miles when I got it and now has 6. I asked the previous owner if he had done anything to the carb and he said no.
I'm still not very good at navigating this site but I'm sure the info is here somewhere. What I'm wondering is what should I jet my carb at? It pops out the breather when I take off from stops. Which I've been told is from running too lean. Also the other day I had to pull off my pipes while putting on forward controls (to get the old right peg off). So while my pipes were off I noticed that my exhaust valves sorta white.
I'm sure its running too lean and needs to be rejetted, but I'm young and still somewhat ignorant in the way of the carburetor. So if someone could maybe direct me to a thread on this or let me know some popular jet sizes on an 883 with my upgrades, it would be most appreciated!
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
If it's been upgraded to a high flow air cleaner and not rejetted it's probably running a little lean. By the way, I really like those Bobcat Exhausts. I think they're the best looking 2-1 exhausts on the market. Here's the link you need for properly adjusting your carb: http://www.xlforum.net/vbportal/foru...d.php?t=642408
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
Francois's Avatar
Francois Francois is offline
Sportster/Buell Model: XL883 C
Sportster/Buell Model #2: FLSTC
Sportster/Buell Year #2: 1992
Other Motorcycle Model: XL 883 (sold)
Other Motorcycle Year: 2008
Francois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant futureFrancois has a brilliant future
Welcome to the forum from South Africa!! Jim (above)got your question sorted out I believe?
Bob F's Avatar
Bob F Bob F is offline
Welcome to the XLForum. The above link has everything there is to know about jetting!
Old Goat Ninja's Avatar
Old Goat Ninja Old Goat Ninja is offline
Sportster/Buell Model: XL1200R SOLD
Sportster/Buell Year: 06
Old Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to all
Gratz on bike and welcome to forum... 06 R's are my favorite
Old Goat Ninja = user formaly known as Starleak
roadtrip's Avatar
roadtrip roadtrip is offline
Non-ancraophobic
Sportster/Buell Model: XL1250C
roadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud of
Welcome to the forum,enjoy the ride.
Bear say's:
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
Welcome from Philly.
I agree with jharback that it is running a little lean. Most likely will need to rejet at least the main.
John Wayne - "The Shootist"
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
Also, you may have an intake or exhaust leak:
Intake And Exhaust Leaks Tests
Folkie
'The green machine'
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
Welcome from Indiana, You may also try reading the CV40 Carb article on www.nightrider.com which also has some good info. Basically if its popping off idle you either need one size larger pilot which should have been changed when the aircleaner and pipes were changed. Or it also needs to add two #4 washers under the head of the needle to fatten up the mid range. After doing this you may find that you can go down one size on the main!
Folkie's Avatar
Brass Nut
It may not need richening so much that you actually need to change the slow jet; you may just need to tweek the idle mixture needle.
