Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Marks Moto Gear
Licks Holiday
CV Performance
The Dart Flyscreen
Old 17th January 2011
dino's Avatar
dino dino is offline
Sportster/Buell Model: xl883 sportster
Sportster/Buell Year: 06
dino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the roughdino is a jewel in the rough
Default When your battery starts to go.....
Ok my bike is a 2006 and has the original battery. I think the battery is starting to go or I need to take everything out and clean and tighten the connections. For you that have had a battery go out, here is the question...
When I first crank it up cold it turns over slowly for the first couple seconds and then kicks in to normal speed and starts. When I've had car batteries go they start out close to full speed and get slower as you crank. It seems weird to me that it cranks faster after the first few seconds. I know the girl don't like the cold but at 50 degrees that shouldn't be a issue.
So is that how your battery started to act before it went out?
Old Goat Ninja's Avatar
Old Goat Ninja Old Goat Ninja is offline
Sportster/Buell Model: XL1200R SOLD
Old Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to allOld Goat Ninja is a name known to all
Mine does the same thing.. but she starts so I figure all is good. First crank over or 2 are real sluggish, almost like it wants to die. But every crank over after this is fast and she starts up after a couple when it's cold. Their carb'd so I think it's normal. I had a carb'd sport bike 15 or so years ago, and it did the same thing in the cold. But she fires right up after rest of the day. Just that first one after sitting a day or 2 or 5
Old Goat Ninja = user formaly known as Starleak
dino's Avatar
I don't remember it always doing it, seems more recent. Could be the combination of it being a little colder and only being rode once a week. Never does it the same day even if it has cooled completely.
dino's Avatar
I almost don't want to take it apart until I have to because the cover is such a pain in the azz
I just bought this bike at the end of last summer, so I have no idea if this is normal for cold weather. But like you it only does it that first time. Rest of day it'll fire right up, even after cooling.
I started to get into battery area once, and it was such I pain I stopped lol
dino's Avatar
so I take it you have the original battery? Maybe someone will pipe in that had to replace one already.
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to beholdtoe is a splendid one to behold
3 things.........
1. I've had that happen with iffy connections.
2. How cold is it?
Batteries have less power when cold. The initial load will warm up the battery, giving it some more power.
3. How cold is it?
With thick oil, it's harder to get things moving, and then it loosens up with a few cranks.
Ed
The Only Y2K dual-set 883C
So Cal
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster!!
Sportster/Buell Year: 01
My buddys 06 1200c does the exact same thing..hesitates too..till one day it just clicky clicky clicky, but no start cause it progressed to completly dead on a 800 mile road trip we where on..
RTFS
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
Yeah dino, I am assuming it is the original battery. Only had 6,7xx miles on it when I bought it. Still has original tires so guessing battery too.
@ toe I've also heard people say that about loose conections giving these kind of problems...
Xcellent01 It could be that it's time for a battery. I also have an 06, so that's makes mine, dinos, your buddies etc kind of old now. I've never had a sport bike battery last over 5 years, so assuming true would be here too.
xllent01's Avatar
Xcellent01 It could be that it's time for a battery. I also have an 06, so that's makes mine, Dinos, your buddies etc kind of old now. I've never had a sport bike battery last over 5 years, so assuming true would be here too.
Possibly after checking the connections or doing a volt test
My buddy already replaced his up in Roanoke VA on a road trip we where on last year..
My original battery (01) went 6.5 yrs before replacement was needed..going on 4 yrs on the replacement one
