24th January 2011
Posts: 245 Sportster/Buell Model: XLH Sportster/Buell Year: 1968
Flat fender with swingarm
I really like the flat trailer fender look, but I have a swingarm bike. I've seen some posts where people mount one to their swingarm. I've seem some pics where it looks cool, some where it doesn't. Are there any other mounting options with a swingarm?
24th January 2011
Banned
Posts: 3,923 Sportster/Buell Model: XLH/I.R.C. Special Sportster/Buell Year: 1974
You can clean up a stock fender by...
...trimming the "skirt" that hangs below the fender struts when it's mounted and radiusing what's left over at both ends.
Lowering the bike with shorter shocks will also work wonders on eliminating the ass-in-the-air dirtbike look of a stock IH.
Big Twin shocks are cheaper, stiffer, and come in more varieties than their Sportster counterparts.
25th January 2011
I've already got some shorter shocks, really like the flat fender look though. Anyone else have any mounting ideas when using a swingarm?
27th January 2011
Posts: 1,113 Sportster/Buell Model: XLH bobber Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1969 Other Motorcycle Model: Kawasaki ZX6E Other Motorcycle Year: 1994
The end that goes down to the front of the swing arm, make an L shaped flange to either weld tot he fender and bolt to the swing arm, or weld to the swing arm and bolt to the fender, or bolt to both, then run hard tail style fender struts in the rear of the fender.
27th January 2011
Posts: 1,542 Sportster/Buell Model: XL1200C Sportster/Buell Year: 1998 Sportster/Buell Model #2: 883/1200 Hugger Sportster/Buell Year #2: 1992 Other Motorcycle Model: Bonneville Other Motorcycle Year: 1971
I used a piece of flat bar for a spring seat mount (drilled and tapped the horseshoe/shock mount) Then I cut a window in the fender so I could mount it to the flat bar. The rear is supported by the swing arm when I installed the struts. When I had shocks, I used spacer at the original lower mount (above the swing arm pivot) . On another bike, we removed the fender struts, drilled the fender and used the strut mount holes on the frame (tapped those and installed bolts from the inside) and also used the lower mount by the swing arm...
In this pic, you can see the mount under the seat.
Life may begin at 30, but it really interesting around 150!
27th January 2011
I don't know how to weld yet, definitely on the list though. Would drilling a hole in the swingarm weaken it to the point of failure? I've also wondered about maybe a couple of conduit straps on the swingarm for the bottom mount then regular hardtail fender struts for the upper mount.
27th January 2011
Posts: 115 Sportster/Buell Model: xlh Sportster/Buell Year: 73
I used a flat trailer fender on mine. It was a perfect fit between the fender struts. The fender sat right on top of the nubs on the inside of the fender struts. I did cut and weld the fender a little to give me just a little more clearance at the front of the tire. I welded some thick washers to the inside of the fender. and bolted it on.
'73 XLH "in progress"
27th January 2011
Banned
Old Iron --- You kept the frame-mounted fender struts...
...with your swingarm-mounted fender.
Are you getting any binding or warping from the bike going over bumps, potholes. etc.?
The two would seem to counteract each other, flexible vs. fixed mounting points, unless I'm missing something.
- SPORTSTER -
Kicking Big Twins in the motherf******g NUTS since 1957
CTFS/QCB
Viva Los Bastardos!!!
1st February 2012
Posts: 27 Sportster/Buell Model: 883 Sportster Sportster/Buell Year: 2002 Sportster/Buell Model #2: Iron Head Sportster/Buell Year #2: 1983 Other Motorcycle Model: Road King Other Motorcycle Year: 1998
- SPORTSTER -
CTFS/QCB
Yeah, I was wondering the same thing. I would think that you would need a hinge on the fender. The swingarm goes up when you hit a bump, so with a hinge the fender woundn't bend, and bind, or whatever other terrible things could happen.
Although this is theory. Looking for other input on this.
1st February 2012
Posts: 255 Sportster/Buell Model: XLH Ironhead Sportster/Buell Year: 1974 Sportster/Buell Model #2: FLH 80 Shovelhead Sportster/Buell Year #2: 1981 Other Motorcycle Model: XLCH Ironhead (basket) Other Motorcycle Year: 1972
Swingarm Mounted Fender
My no weld setup:
Right side at swingarm:
Left side at swingarm:
| Thread Tools |
| Display Modes |
