1st February 2011
Posts: 181 Sportster/Buell Model: Nightster Sportster/Buell Year: 2008
Whats your daily starting routine..?
Probably sounds like a silly or "everyone knows" type question but just wanted to compare notes with others and survey to find out what others daily bike starting routines are.
I have a 2003 883 and since I've owned it (2 1/2 yrs), it has always started by fully pulling out the choke and cranking it. Unless it was cold outside it would start up. Otherwise I might also have to try cranking it over a couple times before it would start.
My mechanic, Ive been getting it serviced at, however, told me I shouldn't have to use the choke, and shouldn't at all, as it will foul the plugs and to pull the throttle back a little while starting my bike, on a cold start. When he tried to demonstrate this to me however it took him a couple tries to get it started but he didn't use the choke on a cold start.
Then I just recently got my bike serviced at a Harley dealer and they adjusted my bike so it naturally idles a lot lower. So low in fact that when I first start it up it will stall at the first couple lights unless I hold the throttle on a little. Didn't go back to ask about this but this is a little annoying as previously when my bike was started, and warmed up a little, when I turned it off it would start back up instantly and beautifully. Now if it stalls it wont start right back up and Im sitting there in the middle of the intersection trying to crank it over and get it started..
Anyway, then it eventually seems to be fine after being warmed up but idles so low I constantly think its going to stall and is super quiet compared to the way it had been.
Anyway, now if I pull the choke out fully on a cold start it doesn't start and I have to try 3 or 4 times, sliding the choke in and out to get it to start...
What is considered the exact routine on this or does everyone have their own or have to piddle around like this..
Not sure if my bike is now properly adjusted and Im just not used to it and have to adjust my routine a little, but w/ the new adjustment it seems very tempermental...
1st February 2011
Nobody Special
Posts: 138 Sportster/Buell Model: XLH883+ Sportster/Buell Year: 2002 Other Motorcycle Model: Harley Davidson FLHTCUI Other Motorcycle Year: 2000
after its warmed up turn up the idle screw a little untill it idles a little faster
1st February 2011
Ok, so it sounds to you like the idle was turned down too low..
Do you cold start w/ your choke..?
1st February 2011
Nobody Special
allways thats why its there
1st February 2011
Posts: 125 Sportster/Buell Model: xl 883 Sportster/Buell Year: 1996 Sportster/Buell Model #2: zx14 neeenjaa san Sportster/Buell Year #2: 2007 Other Motorcycle Model: Triumph Thrux Ton Other Motorcycle Year: 2005
My mechanic, Ive been getting it serviced at, however, told me I shouldn't have to use the choke, and shouldn't at all, as it will foul the plugs ..
Do the '03's have a choke or an enrichener?
1st February 2011
Posts: 1,621 Sportster/Buell Model: XL1200 S Sportster/Buell Year: 1996 Other Motorcycle Model: Suzuki M109R Other Motorcycle Year: 2008
Normally I give the throttle a twist and pull the enricher all the way out, once it starts control the idle speed with the enricher. Ride a few blocks and then push the enricher all the way in, this is with a cold start. Warm start, just push the starter.
On the Highway to Hell, no stop signs, no speed limits.......
1st February 2011
Ride That F'N Sportster!!
Posts: 12,350 Sportster/Buell Model: Highly modified 1200 c Sportster/Buell Year: 01 Other Motorcycle Model: FLHX H-D Street glide Other Motorcycle Year: 2013
+100
Thats the same procedure I follow..works just fine even with cold or warm starts..Ride Safe!!
RTFS Ride That F'N Sportster!!
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
1st February 2011
Posts: 1,127 Sportster/Buell Model: 1200S Sportster/Buell Year: 1998
+1 That's how I start mine as well...
1st February 2011
Posts: 913 Sportster/Buell Model: Sportster Sport XL1200S Sportster/Buell Year: 1998 Sportster/Buell Model #2: Fatboy 1450 FLSTFI Sportster/Buell Year #2: 2002 Other Motorcycle Model: Kawasaki KDX125sr Other Motorcycle Year: 1991
+1 Thats the same way I start mine... Works for me, I just gauge when the choke needs to go in, if you leave the choke out too long, thats when you will foul the plugs!..
I can normally ride about a quarter/half a mile & thats the engine warm enough to put the choke full off & idle correctly at lights.. & thats at around 12 degree Celsius (53 degree Fahrenheit)...
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
1st February 2011
Posts: 737 Sportster/Buell Model: XLH1200 Sportster/Buell Year: 1995 Sportster/Buell Model #2: S3T Thunderbolt Sportster/Buell Year #2: 2000
This is my routine: - Insert key and turn ignition on. Check
- Turn run switch on. Check
- Depress front pressure relief valve. Check
- Depress rear pressure relief valve. Check
- While pulling choke knob out, press start button. Check
- Wait for bike to start (one or two revolutions after pressure valves close). Check
- Simultaneously twist throttle to maintain idle while closing choke. Check
- Use cheater lever to hold throttle at low but even idle. Check
- Finish putting on gear. Check
- Release cheater lever and ride on! Check!
LOL!
can you tell I am bored this morning...
EDIT: BTW, for the first couple of years that I owned my sporty, I thought the choke pull was automatic and it would shut itself off when the bike was warm enough. My mechanic laughed when I told him this one day but as he was playing with my setup, he noticed that I was partially right. When my engine warms up, my choke knob will not stay open. It will also close if I accelerate hard.
"...Dumb all over, A little ugly on the side... "...Frank Zappa...
| Thread Tools |
| Display Modes |
