famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27) |
4th November 2007
Posts: 679 Sportster/Buell Model: 1200xl Sportster/Buell Year: 2006 Sportster/Buell Model #2: 1966 mustang 302hipo Sportster/Buell Year #2: 1974 Other Motorcycle Model: sporty in pieces
real wheel alignment
I need some expert tech advice....
has anyone measured their real wheel axel to determine alignment?
today after adjusting my chain tension I was unable to get the rear wheel into perfect alignment...the drive side is 1/4 in further back....the tension nuts will not allow perfect alignment unless the chain is too slack......the distance is not quite a link so shortining the chain is not an option
????? the bike tracks well and stops fine...so far (without highway testing)
any ideas..I'm aware of the uneven tire wear issues and possible high speed handling instability...so whats the remedy? shocks are mounted fine WTF
4th November 2007
Posts: 756 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 2001
Don't measure from the tension nut area. measure from the swing arm axle to the wheel axle. hope this is the info you are after
1200 XLH, "D" shaped exhaust port, SE 497 cams, 9.5:1 CR, 1.850 inlet & 1.615 exhaust valve, 48 primary & 190 main jet, NOKK needle no shim. 84TQ & 81HP
4th November 2007
Swing-arm pivot to rear axle.
4th November 2007
thats the measurement I used fro the swingarm bolt dimple to the centercup of the rear axle......still I'm 1/4' off????
4th November 2007
Adjust the side with the chain, then measure and adjust the other side, check and readjust as require, but this is the way it is done. sorry I can not help further. good luck
4th November 2007
Posts: 1,416 Sportster/Buell Model: FatBob Sportster/Buell Year: 2009 Sportster/Buell Model #2: all gone 1200R Sportster/Buell Year #2: 2007 Other Motorcycle Model: Honda ST1300;Goldwing1500 Other Motorcycle Year: 0407
Is your '06 a chain conversion? If so, were the sprockets changed?
I'm not sure about on a sporty chain, but on my old 250 Kaw desert racer, I used a half link, not a full link, to shorten the chain a half a tad.
2009 FatBob-Black Pearl- "almost" no mods yet
Not gonna mod this one........
except for the Screamin'Eagle pipes, Heavy Breather A/C, MoCo ECM reflash, Switchblade pegs, MicroTach, Deflector Dx Windshield, Garmin Zumo GPS, T-bag Stow-away, bob tail rack, HD bags with BareBacks,and last, but not least, the VIED's, and now the very lastest-Ricor's Intiminators with 5/8" cut off the stock spring pre-load spacer. Oh well, I tried to hold out.
Use to have 1200 R:
Taxes Paid
Hurricane A/C forward offset
S/E Street Performance Muffs
Dealer factory re-map-Vied's currently AFR set @
back to 14.0:1
Mustang Vintage Touring Seat
T-bag stowaway/modified license plate bag.
HD adjustable hi-way pegs
Stebel Compact Nautilus [COLOR="Red"][SIZE="5"]LOUD[/SIZE][/COLOR] horn
Hybrid shocks with 1 " pre-load spacer
Progressive standard fork springs
w/ 2 1/2" pre-load; 12 oz 10 wt Amsoil in each
4th November 2007
Known Troublemaker !
Posts: 7,347 Sportster/Buell Model: Sportster 1200C Sportster/Buell Year: 06
I USed the Method called for in the manual, Using a piece of welding wire with a rubber grommet for a marker, Basically it will compare the distance from the Swingarm Axle bolt to the Wheel Axle bolt.
This should work provided the frame is straight !!
You can put in a Half link like was mentioned. But something else seems to be amiss here... Why your having so much trouble getting it aligned I don't know ??
4th November 2007
it's a chain conversion on an 06 I used a 52 on the tranny and a 48 on the rear wheel I cant remember the exact # of teeth yet that combo seems right
my big question is
is it safe to run like this???
guess I will find out around noon today when I go out
| Thread Tools |
| Display Modes |
