16th March 2011
Posts: 8 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974
Bendix Throttle Cable Mounting 74xlch
I'm not sure if I have the wrong bracket for the cable or if I'm missing another piece to line up for a straight pull for my cable. I just took it apart a few yers ago, but hell I can't remember last week! I can't find another bike to compare it to around here so any help (pics) would be much appreciated.Thanks in advance everyone.
Reason: Fixed link to image
16th March 2011
Posts: 373 Sportster/Buell Model: Sportster XLH Sportster/Buell Year: 1973 Sportster/Buell Model #2: Sportster XLX Sportster/Buell Year #2: 1983 Other Motorcycle Model: Harley Davidson FLH Other Motorcycle Year: 1976
That is exactly the same setup as my '73 XLH.
The cable lock screw is on swivel shaft.
The throttle cable bracket is held between the top stud and nut of the carb.
...as an aside, looks like you have an "idle tube" or "non-adjustable main jet"...
been down that road the last few days...
And it should be screwed in flush (as you have it) but there should be a thin washer under the head, not sure if its fiber or ???
When you install the throttle cable, make sure the is no tension on the throttle lever
...it can open your throttle plate ay idle...trust me on this one,
I had this problem (this past week) when I re-installed my carb after my rebuild
Dee
16th March 2011
Posts: 630 Sportster/Buell Model: 883R Sportster/Buell Year: 2003 Sportster/Buell Model #2: XLCH 1000 Sportster/Buell Year #2: 1972
I made a bracket off the idle screw so it just pulls straight up. keeps the inner cable from rubbing against the metal end of the outer cable I take a pic and post it this afternoon.
"WFO From The Get Go"
1972 1000 XLCH
2003 883R
16th March 2011
Posts: 578 Sportster/Buell Model: 1200 Sport - 4 Plug Sportster/Buell Year: 1999 Sportster/Buell Model #2: Triumph T-Bird 900 Triple Sportster/Buell Year #2: 1998 Other Motorcycle Model: Wife's T-Bird 900 Triple Other Motorcycle Year: 1995
Huh. A throttle return spring on the throttle shaft to hold it aginst the idle screw. What a clever idea!
Anybody got a spare?
16th March 2011
Posts: 1,582 Sportster/Buell Model: FLCH Sportster/Buell Year: 61 Sportster/Buell Model #2: XLCH Kit Bike Sportster/Buell Year #2: 60
ya don't need it....instead you've got 'cruze control...old skool'
Scott
'61 'CH
'60 'CH
16th March 2011
Posts: 233 Sportster/Buell Model: XLH Sportster/Buell Year: 1974 Other Motorcycle Model: Yamaha Maxim Other Motorcycle Year: 1982
That's identical to the setup on my '74 XLH. Works good, I think I was able to rotate that bracket outboard just a little to give it a straighter pull but its been working fine either way.
16th March 2011
Naaaa. I think I'm gonna use a spring. Within my first mile of my initial ride, the throttle stuck at about 1/2 throttle (2,500r). Now I've adjusted and tickled the cable more than a few times since but the throttle and the piano wire just won't hold the throttle shaft snug aginst the idle screw every time. Just need that last, final nudge of help.
I was just gonna use a spring from the hardware store between the cable stop screw and the air cleaner base... but man, the stock spring sure is cooler.
Oh, BTW, my cable is about 90* off pictured. Almost about flat coming across between the rocker covers and pulling/pushing pretty straight through the throttle's swing. edit: '72XLH
16th March 2011
Mine has the stock spring on it, I still added an extra just to be sure. I've got a lead wrist on take-off so the stiffer throttle helps to keep me on the bike!
17th March 2011
Posts: 2,801 Sportster/Buell Model: XLCH Sportster/Buell Year: 1971 Other Motorcycle Model: FXDL Other Motorcycle Year: 2003
jdxlch's pic looks normal to me.
It appears he is using a braided throttle cable.
When he opens the throttle the arc on the cable shown in the pic begins to straighten out.
I use the original hard wire throttle cable and when I set mine up I wanted a straight shot if possible.
Well, it is not possible but I eliminated most of it by making my own cable holder.
I made this out of a pair of Quik Fasteners. Two halves go around a round brass ball.
This allows the housing to rotate as the throttle is opened and closed. It works pretty, although I do not think it is really necessary.......
pg
17th March 2011
Posts: 1,450 Sportster/Buell Model: XL1200 Low/TTS/Gronked Sportster/Buell Year: 2007 Sportster/Buell Model #2: XLCH1000 Sportster/Buell Year #2: 1975
Yep, that is correct. You could turn the barrel around on the throttle lever to make it a little easier to tighten the cable screw. Also, the original has a brass ferrel crimped onto the cable end to prevent it from fraying, still available from HD. I've heard you can also find it at hobby/craft stores, just a very small dia piece of brass tubing.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
| Thread Tools |
| Display Modes |
