The Sportster and Buell Motorcycle Forum Get Lowered Sportster
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Drivetrain > Sportster Motorcycle Tires, Wheels, and Brakes
Flying Piston
Zippers Performance
Dead Creek Cycles
Old 3rd April 2011
Stevodod's Avatar
Stevodod Stevodod is offline
Sportster/Buell Model: 1200XL Sportster
Stevodod is on a distinguished roadStevodod is on a distinguished roadStevodod is on a distinguished roadStevodod is on a distinguished roadStevodod is on a distinguished road
Default Can't get rear wheel back on right? GRR!
Feel like the world's worst mechanic here, done this several times, but I just can't get the rear wheel back on right- it's on now, but the bolts heads on the belt pulley are hitting the swingarm.
There is no more space for another spacer, I can't figure it out?!!!
Help?
Steve
People fear debate because they either can't control their emotions or can't back up their arguments with facts, so they avoid it. Or they are larger and stronger than you and hurt you physically!
Old 3rd April 2011
rottenralph's Avatar
rottenralph rottenralph is online now
rottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant futurerottenralph has a brilliant future
Spacers are on wrong side. Pulley side gets the longer of the two. Why was the wheel off?
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
Old 3rd April 2011
Stevodod's Avatar
Default changed rear tire
I changed out the rear tire- now that makes sense!
Thanks,
Steve
Old 3rd April 2011
Mine has two spacers on the sprocket side to accomodate wider tire. I imagine if you look at the tire from the back it is not centered with your current spacing.
Old 3rd April 2011
Stevodod's Avatar
Yup, 2 spacers- damn fool I feel like!
Thanks!
Old 4th April 2011
Thats what we are here for. Most lesons learned here have been learned many times. Glad you got it sorted out.
