Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Foxcreek Leather
Fix My Hog
Marks Moto Gear
Primordial Cycles
Speedway Instruments
Old 25th May 2011
Dirk Diggler's Avatar
Dirk Diggler Dirk Diggler is offline
Dirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the roughDirk Diggler is a jewel in the rough
Default Tire pressure?
Just wondering if sticking with the pressures specified in my manual are going to be best (36 rear, 30 front) or if more experienced XL owners have found that different pressures work better.
I'm open to all input.
Thanks all!
-DD
2003 VRSCA 100th anniversary editon. Black/Silver. Stock.
Old 25th May 2011
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: 1200Lr
Sportster/Buell Model #2: Guzzi V7
Sportster/Buell Year #2: 2013
Other Motorcycle Model: Ducati M696
Other Motorcycle Year: 2011
Bone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant futureBone has a brilliant future
I assume you're still running the stock tires?
If so, those pressures are a great place to start.
You can try a little lower for a little more grip (but a little less mileage).
You can try a little higher for a little more mileage (but a little less grip).
You should probably run a little more for higher loads (be that if you're a particularly big guy or 2-up or you plus luggage etc).
Old 25th May 2011
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
I always ran the recommended pressures with the stock tyres, and they were fine; never had a reason to vary them.
Folkie
'The green machine'
Old 25th May 2011
BKB's Avatar
BKB BKB is offline
BKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to all
Old "rule of thumb" that I & some others use is 4lbs less than the max pressure stated on the side wall. Works well with every tire I've ever used, bike or car. Plus you don't have to remember anything but 4 less. Less to remember is always good for us old farts. 8-)
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
I didn't buy a Sportster 'cause I wanted a Harley... I got a Harley 'cause I wanted a SPORTSTER!!! He who gives up liberty for security, will have neither. Ben Franklin
Old 25th May 2011
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
khaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud of
It is a DOT requirement to print the tire pressure on the sidewall.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 25th May 2011
Bone's Avatar
I don't mind rules of thumb, HOWEVER that one makes little sense to me.
If it were a percentage MAYBE MAYBE MAYBE, but considering tires on bikes, cars, trucks and trailers can vary in max pressure settings by nearly double the recommended spec, I don't like using a set figure below max.
Not to mention, I don't mind running my 4 wheel vehicles at higher pressures for better mileage and less grip because they won'd slide out from UNDER ME if I lose traction.
But MOTORCYCLES aren't as forgiving if you start to slide, so I prefer to run at the BIKE MANUFACTURER's recommendations or the tire manufacturer's model specific recommendations if available.
It is only a DOT requirement to print the MAXIMUM ALLOWED PRESSURE - i.e. the pressure designed for carrying the MAXIMUM LOAD for which that tire is rated, and it is quite likely that same pressure WILL NOT yield the best traction for MOST applications.
The number one biggest DIYer mistake is airing their tires to the MAX sidewall pressure thinking that is "best" for all applications and that is simply incorrect.
Old 26th May 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
"Nothing but the best for my baby"
Yeh.........I'm just stirring the pot! It's raining again!
Hey....let's talk about using Nitrogen!
Stuff: YES
Old 26th May 2011
gerblawman's Avatar
gerblawman gerblawman is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: Yamaha Radian - previous
Other Motorcycle Year: 1986
gerblawman will become famous soon enoughgerblawman will become famous soon enoughgerblawman will become famous soon enoughgerblawman will become famous soon enoughgerblawman will become famous soon enoughgerblawman will become famous soon enoughgerblawman will become famous soon enough
while we're on the topic of tire pressures, I have a question.
The other day I went out to check my tire pressure, but I was having a hell of a time getting a reading from the valve stem. It's almost like the valve is bent and not opening properly for a reading. When I am able to get a reading, it is below recommended level. To the same effect, it doesn't seem to be taking in air when I put more into it... any ideas?
Also, nitrogen would be great for bike tires I think. Has anyone done this?
- Some say that he lives in a tree, and that his sweat can be used to clean precious metals...
2002 883R
Old 26th May 2011
St_Anger's Avatar
St_Anger St_Anger is offline
Sportster/Buell Model: Nightster / XL1200N
St_Anger is on a distinguished roadSt_Anger is on a distinguished roadSt_Anger is on a distinguished roadSt_Anger is on a distinguished roadSt_Anger is on a distinguished road
My 2010 owners manual says 30 front & 40 rear.
Anything less than 30 upfront and the bike feels quite sluggish.
Service rep at HD told me i ought to run it even higher in the rear tire but i'm comfortable with it at around 38.
On the topic of nitrogen, Ive heard that in the event of a puncture you'd have less of a 'blow out' effect. Also that the tire would maintain its pressure longer and be less susceptible to temp variations......
Old 26th May 2011
Bone's Avatar
Not sure about the why, but I think my first thought would be to get a valve stem core tool and pull the stem (that is if they are mounted like car tire valve stems) to inspect it.
Nitrogen - probably more effort than it is worth. It's really only become a benefit for over the road trucks.
Yes, the tire may maintain pressure longer, and be less susceptible to changes from heating up (but that's not necessarily a good thing, since specs are for cold tire pressures and they take into consideration a certain amount of additional pressure from heating up). The blow out effect sounds like myth.
Here's an article which addresses it in passenger cars
http://www.popularmechanics.com/cars...stions/4302788
So, to answer your specific questions: With nitrogen, your tire pressures will remain more constant, saving you a small amount in fuel and tire-maintenance costs. There will be less moisture inside your tires, meaning less corrosion on your wheels. You will not be able to feel any difference in the ride or handling or braking, unless your tire pressures were seriously out of spec and changing to nitrogen brought them back to the proper numbers.
Here's a business article saying it's not worth it
http://www.foxbusiness.com/personal-...th-added-cost/
An NHSTA test of hundreds of tires found the same thing, that nitrogen filledtires lost approximately two-thirds as much pressure as air filled ones.
<snip>
What about the tire deterioration issue? NHTSA testedboth air and nitrogen filled tires for aging. They found the results were"inconclusive."
