12th June 2011
Posts: 10 Sportster/Buell Model: XLCH Sportster/Buell Year: 1976
S&S Carb Issue or intake?
First time post. I have a 76 XLCH with the following stuff: S&S "E" shorty, Andrews PB+ exhaust cams, Dyna S single fire electronic ignition with 3 ohm coils and a custom 2 into 1 exhaust that is short. Starts right up, no hesitation on take off, steady climb to speed. You can see the new exhaust on my posted picture of the bike. Oh yea, the exhaust does have baffles installed where the 2 into one is mounted.
Everything fine until I changed from full length drag pipes to the new exhaust. Ran into the dreaded 50mph dead band. My carb is an older S&S so I drilled the main air bleed to .048 and dead band went away. (thanks to the forum's guidance.)
Now problem is a cough (hiccup?) at about 60mph. At a steady 60mph, it will do this randomly and keep doing it until below 55. Right now the carb has a
.0295 intermediate and I've tried from .068 to .072 without clearing that cough. Checked for air leaks on intake without finding any. Overall seems to be running slightly rich, but not bad. Checked some other things like pushrod adjustments (good), wiring (still good), gas flow to carb (sigh, good), and carb adjustments (per S&S instructions, good).
Could this be still a carb issue (butterfly shaft and such) or timing (checked and seems to still be on the money)? I'm really at a loss and looking at other carbs (which is gonna be expensive)  .
Bikereff
Arizona
Bikes, guns, and Beer.
12th June 2011
Banned
Posts: 1,613 Sportster/Buell Model: XLH Sportster/Buell Year: 1976
Air filter?
12th June 2011
Posts: 138 Sportster/Buell Model: XLS 1000 Sportster/Buell Year: 1983 Other Motorcycle Model: GSXR 600 Other Motorcycle Year: 2003
that sounds like a back pressure issue to me
www.bloggingbiker.com
12th June 2011
On the backpressure, too much or not enough? Never have run into the issue before. Any ideas on how to fix?
12th June 2011
The pipes do have 3 inch long baffles installed in each pipe at the 2 into 1 junction.
10th August 2011
Switched to Mikuni
Well, I gave up on trying to match the S&S Shorty to the pipes I installed. Got a great deal on eBay for a Mikuni 40mm carb. Installed and WOW  what a difference it made. Runs really good just bolted on. Got finished with adjusting the pilot system and now it idles very well and starts on the 1st or 2nd kick every time.
Now I'm just dealing with a small exhaust leak on the front cylinder.
10th August 2011
Posts: 15,406 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
Sounds to me like its your pipes. It's to be expected with short pipes like that. They're made for looks not performance. They're going to have some dead spots and some popping on decel.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
10th August 2011
Posts: 1,335 Sportster/Buell Model: xlch Sportster/Buell Year: 1977 Other Motorcycle Model: BMW K-1200/GT Other Motorcycle Year: 2004
The decel popping is caused by a lean fuel mix. Which is caused by the shorter pipes.
12th August 2011
Haven't had much popping and when it happened it was very light. I adjusted the carb to try to compensate for the increased flow and the plugs show medium brown right now.
The only problem (which is interesting, and looks cool) the the 2-3" blue flames that sometimes come out of the end of the exhaust when going above 50 mph. Pretty sure it is an exhaust leak at the clamp.
12th August 2011
Posts: 959 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
Or an air leak
Sportster XLCH 1975
Wiseco 10:1 forged pistons, Ported Heads , Andrews R5 cams,full set Andrews gears, S&S E series, MSD solid state single fire ignition, Accel Super coil, straight pipes, blah blah,.... blah blah
| Thread Tools |
| Display Modes |
