Don's Cyclewear
Figure Machine
Ironworks Magazine
NRHS Performance Long 2
Biltwell
Old 21st June 2011
lukedeuce's Avatar
lukedeuce lukedeuce is offline
Sportster/Buell Model: Custom
Sportster/Buell Year: 97
lukedeuce is an unknown quantity at this point
Default Chirp in 5th
I have recently been hearing a chirp when in 5th gear, but it is only when I have a rider and it doesn't happen every time. I checked the forum and found a couple of suspects (primary, clutch, etc...) but still can't find anything wrong.
The only other thing I can think of is the exhaust, but all the gaskets look good and everything is tight.
Thanks for the help
LukeDeuce
97 Sporty Custom 1200.
99 FZR w/ R1 Conversion
Old 21st June 2011
rocketmangb's Avatar
Jester Mafia
Other Motorcycle Model: 48
rocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant future
Check the drive belt
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
Old 21st June 2011
lukedeuce's Avatar
Just replaced not too long ago. Not frayed and still almost brand new. Everything is still aligned correctly
Old 21st June 2011
Jester Mafia
Check the adjustment
Mine would chirp when the air temp was low and before the belt was warmed up
Old 22nd June 2011
southplatte's Avatar
southplatte southplatte is offline
Sportster/Buell Model: XL883C
southplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nicesouthplatte is just really nice
+1 mine did that, usually only prior to the belt warming up as well.
08 XL883C - Saddle Bags, RagerBuilt Custom Exhaust, FuelMoto EFI, K&N High Flow A/C
Old 22nd June 2011
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
Also make sure your tire isn't rubbing somewhere under the fender when you have a passenger.
Stuff: YES
