20th August 2011
Posts: 760 Sportster/Buell Model: 883L Sportster/Buell Year: 2006
To leave it run out of fuel; Or not?
Was drinking some brew with a buddy and don't know what brought the subject up; But he told me he had been taught to always close the petcock and let the engine run out of fuel before parking it for the night? I never heard that one...Any opinions or facts for this?
20th August 2011
''Under control''
Posts: 2,984 Sportster/Buell Model: xl 883c<1212 Sportster/Buell Year: 2005
I never do. Never have heard it either. if the bike didnt have a shut off, sure. But its designed with one. on top of that when you start it next time you will be turning the motor till the carb fills up and sends fuel to the bike. Not a good idea if you ask me.
With all the dumb-asses in the world, you'd think a smart-ass would be shown more appreciation. - Biker Dude Dref
hp = (torque x rpm) / 5252
I will work till the zombies come, then I play- Char_dHin
Amidst the mists and coldest frosts,
With stoutest wrists and loudest boasts,
He thrusts his fists against the posts,
And still insists he sees the ghosts.
Zombie Leg Humpers M.C.
http://xlforum.net/vbportal/forums/group.php?groupid=90
20th August 2011
Turbo Mafia
Posts: 1,616 Sportster/Buell Model: Turbo Nightster Sportster/Buell Year: 2010
I do it on my dirt bike only because I don't want the oil separating out of the fuel and laying in the bottom of the carb if the bike is gonna sit for a week or so...
1) it can clog the jets
2) separated fuel will kill a 2 stroke engine fast
but with straight gas, I don't see the point.
21st August 2011
Posts: 84 Sportster/Buell Model: sportster Sportster/Buell Year: 1981
if the bike is going to sit for a long time it'll stop from evaporating and causing the varnish effect but it's not days. In the fall when the rides are long time in between I run it dry but it's just something I had started. When it comes time to start you just turn fuel and then take a look at the bike. Once you did your once over and made sure everything is tight then you are sure the bowl or bowls will be full......
21st August 2011
Posts: 550 Sportster/Buell Model: 05 1200R Sportster/Buell Year: 2005 Other Motorcycle Model: V star classic wife's Other Motorcycle Year: 2005
I know the 04-06s have a vacume shut off so even if you turn the petcock to on, till you crank it its not really turned on and no fuel flows to the bowl.At least with the factory petcock.
05 1200R Forcewinder XR air filter, Mikuni HSR 42,Super Trapp 2-1 pipe,TC88a ign., head light visor, chin spoiler, sport front fender, solo seat off 883, 12 and 1/2 inch dual rate Works shocks , dual rate Works fork springs
21st August 2011
Posts: 223 Sportster/Buell Model: xl1200n Sportster/Buell Year: 2011
...? I see no beneft of this...even for the winter fill it all the way up...you just leaving room for corrosion to happen or lines to dry out.
21st August 2011
Posts: 1,535 Sportster/Buell Model: 1200 Custom Sportster/Buell Year: 2004 Other Motorcycle Model: Suzuki DL1000 Other Motorcycle Year: 2002
in a word No
Impact Blue 1200 Custom, Gronk's mod stock exhaust, Ram-Flo 400, 45 slow, N65 needle, 175 main, HD detachable windshield and rear rack/ back rest, lay-down license plate, Mustang wide vintage, Progressive 13 1/2" 418s and Progressive fork springs w/ Belray oil, Superbrace,
21st August 2011
Mental floss
Posts: 4,369 Sportster/Buell Model: sportsterR Sportster/Buell Year: 2105 Other Motorcycle Model: 82 1000sz katana Other Motorcycle Year: abov
to repeat the word...
no.
21st August 2011
Posts: 388 Sportster/Buell Model: XL883C Sportster/Buell Year: 2001
Um, what was that word again?
Oh yeah.
No.
I thought I was wrong once, but I was mistaken.
Ol' Dirtbeard of the Satan's Barbers MC
(from Outlaw Biker name generator)
21st August 2011
Posts: 156 Sportster/Buell Model: XLS Sportster/Buell Year: 1984
Always do. The SU instructions say to. Just turn it on a few seconds before hitting the button, no problem.
1984 XLS Roadster, 42K miles, SU carb, HI-4 Single Fire, Pipes and Andrews Y Cams. Had it long enough I am the PO ;-(
| Thread Tools |
| Display Modes |
