Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Electrical and Ignition
Figure Machine
The Dart Flyscreen
Sportster Specialty
Figure Machine
charging problem, dead battery
Old 27th August 2011
carmine73's Avatar
carmine73 carmine73 is offline
Other Motorcycle Model: flstfse
carmine73 is on a distinguished roadcarmine73 is on a distinguished road
Default Charging issues solved report
Hi all I am a wrench from N.Y. And I have had some serious headaches with an 04 , 1200 custom I figured I can possibly save some of my friends here a few headaches so I will run it down for ya and if anyone can save a minute or prescious riding time or a dollar im a happy guy.
I got the bike with a dead but brand new battery.
I charged the battery and load tested it and found it to be good.
I started the bike and checked the output at the stator and had over 40 vac
I checked the voltage at the battery and had 11.somthing
I immediately suspected the regulator and replaced it
After replacing the reg/rect I was charging at a little over 13.8 volts alls good .....WRONG!
After less than 2 miles my customer breaks down?
No charge no start, so I ohm out the stator and find it is good brand new regulator and battery what the hell?
Apon further inspection I find that the ground strap on the lower rear mount is no good and corroded,
I also discover my customer has over tightned the negative battery terminal damaging the battery
I repair the stuff I found but no charge still
I got so fed up I replaced the entire charging system stator rotor and reg/rect...... I get it all buttoned up fire the bike and tada it still doesnt charge now im steaming im so tyred of messing with this bike I wanna douse it with gas and light it up! I seperate all the connectors checking all the wires and every thing is good. I start it up and its charging. Great I go for a test ride it stops charging im pulling my hair out here and as I go to check that I have every thing connected right the wire ejects from the connector connecting the wire harness of the bike to the regulator!!! I chopped the connector out and spliced it direct with water resistant shrink splices and viola' no more charging problems. The key here is the connector problem was not obvious and intermittant and it also is part of the bike not the component so even swapping parts will not solve the problem.
On two wheels forever and loving it!
seajay's Avatar
seajay seajay is online now
Bike Builder
Sportster/Buell Year: 04
seajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really niceseajay is just really nice
Thanks for the insight.
04 76"C NRHS #2 CP 10.5:1 .575 cams TP rockers TC88A HSR-42 S&Sac LSR 2-1 Can you say--- screamer?
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Thanks for the heads-up!
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
Old 28th August 2011
beano's Avatar
beano beano is offline
Sportster/Buell Model: 1200 xlr
beano is on a distinguished roadbeano is on a distinguished roadbeano is on a distinguished roadbeano is on a distinguished roadbeano is on a distinguished road
thanks man...b.
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
Thanks for posting this.
It sure seems like this is more the norm than the exception on sportsters. The grounds are all always vibrating loose, corroded, or the lug that the factory crimps on to the cable ends is corroded inside, and the plugs are always failing due to either corrosion, or just popping apart like in this case. The ground from the battery in the rubbermounts is in a dumb place, so many of us have moved it to the back of the primary with the other "harness grounds".
So this serves to remind us all to check the wiring carefully before ever ordering parts. It's not like we could ever expect that it would be good.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
