The Sportster and Buell Motorcycle Forum Get Lowered
The Dart Flyscreen
Sportster Specialty
NRHS
Flying Piston
Biltwell
Old 9th September 2011
Grumpy_Chef's Avatar
Grumpy_Chef Grumpy_Chef is offline
Lord of the Flies
Other Motorcycle Model: Fatboy
Other Motorcycle Year: 1995
Grumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really niceGrumpy_Chef is just really nice
Default Rear caliper help for Evo....
I'm going to try and ask this here as most of the more knowledgeable folks hang here. Plus, I do believe my '86 sporty shares a lot of parts with late model IH..
Does anybody know what type of brake line fitting my rear caliper takes? I thought it was a 10mm banjo, but upon a closer look it looks like a 1/8 pipe thread; does this sound right?
Thanks for any help with this.
Matt
'75 XLCH 1000
'95 FLST Fatboy
My '86 XLH build...
Old 10th September 2011
Post a pic of it please. Yes, it could very well be 1/8 NPT. Need to see it.
Lord of the Flies
Hey Mick,
Thanks for replying back... here are two pics of the rear of the caliper. the left piece is the bleeder, the right is where the brake line and fitting go...
What's happening is that the bike originally had a solid brake line from master cylinder to caliper. I hard tailed the frame, so I need a custom length line, but not sure which fitting to use...
I am not thoroughly familiar with the terminology for brake fittings. I think the correct terminology for that fitting is inverted flair. It could be metric or SAE or NPT. I believe that it is not a banjo fitting.
If it is smaller diameter in the hole than at the top then it is NPT.
Hopefully someone who knows will come along.
alank alank is offline
Other Motorcycle Model: V-twin Schwinn Chopper
alank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nicealank is just really nice
I'll agree, that looks like a flair fitting. A banjo fitting would have a nice machined surface around the threaded hole. Do you have the line that came out of the caliper? Lots of automotive brake lines use flair fittings on the ends. You might take it to an automotive store to see if you can find one that fits, then you can determine the size.
mycle1000 mycle1000 is offline
Sportster/Buell Model: xlx61
Sportster/Buell Year: 85
Sportster/Buell Model #2: xl1200r
Sportster/Buell Year #2: 05
Other Motorcycle Model: yamaha vstar 650 custom
Other Motorcycle Year: 00
mycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nice
it is npt fitting. it should be just like my '85 and i used a threaded insert to modify when i changed to aftermarket brakes.
85 xlx61 (with a million miles and a million mods)
05 xl1200r (bought used)
00 vstar650 (for the wife)
66xlch 66xlch is offline
Master Bike Builder
Sportster/Buell Year: 66
Sportster/Buell Model #2: 67 XLH, 63 XLCH
Sportster/Buell Year #2: 67
Other Motorcycle Model: FXRT
Other Motorcycle Year: 91
66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about66xlch has a spectacular aura about
It is inverted flare. NPT is tapered and doesn't have the, well, inverted flare thingy in it. Auto parts store sell a bunch of fittings for them. Mostly they sell straight sections of pipe with the flares and threaded parts already on them, and then you bend to fit yourself. Just be careful because on a bike you need some flexible hose for the chain adjustment, and watch for crimping when you bend it.
ezmerf's Avatar
ezmerf ezmerf is offline
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
One reason is over here in the IH forum your talking with a bunch of old farts that have been around these bikes along time.
Murphy's Law
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of light
I can't see in the hole really well but it doesn't look like the inverted flare surface I've seen in my other brakes. Almost looks like a brass insert of some kind in there. Anyway, the inverted flare thread size would be 3/8-24 and I'd buy a 3/8-24 bolt and see if it threads all the way into the hole. If so, you need the inverted flare adapter for your hose. If the 3/8-24 bolt won't go in smoothly, you'll be dealing with a 1/8-27 pipe size adapter.
Eric
Old 11th September 2011
Originally Posted by Grumpy_Chef View Post
I'm going to try and ask this here as most of the more knowledgeable folks hang here. ...
Originally Posted by DirtyCory View Post
... the evo section of this forum is nothing but ----!!!! ...
The Evo section has good people. They just do not have the technical knowledge and experience that the IronHead guys must have.
