swanny, Mrs Jimi, SnarleyHarley (63), UtahMark, ihjonny (56), fatchuk (55), provision (47), randreb (47), joeyhunter (44), junk runner jr (38), Pegscraper05 (35), cowboy_hamilton1@yahoo.co (34), wi1dwood (34) |
5th October 2011
Posts: 65 Sportster/Buell Model: 1200R Sportster/Buell Year: 2006
110 front tire uneven - video
I recently installed a 110 front tire on my 06 sportster and it is a little uneven when rotated, it even makes contact with the fender strut a little. I shot a quick video to show what is happening.
I installed it a week or so ago and had no rubbing but tonight when I went to roll the bike back in the garage it squeaked upon making contact with the fender so I put it up on the lift to check it out. I looked over the handlebars last week when I rode it and noticed that when rotating at speed the tire was "wobbling" left to right but the bike had no vibes or wobbles, but it struck me as odd that it appeared to be moving side to side. I installed everything just as it came out as per the manual.
Is this an issue with the tire or something I may have done with installing the wheel/fender? I am leaning towards a tire issue but it doesn't make any sense that it was not making contact when I installed it but now it is. I did have the forks off prior to this to install fork boots and I thought maybe the pinch bolts on one side came loose just a little and shifted the fender over a bit, but everything appears even.
Here is a video of what it looks like, I appreciate any advice:
5th October 2011
Super Moderacer
Posts: 6,082 Sportster/Buell Model: XLRR Sportster/Buell Year: 91 Sportster/Buell Model #2: XLH1100 Sportster/Buell Year #2: 80
looks like a bent wheel from where I'm sitting.......
Ww
master wizard
RIP Mr Jimi
5th October 2011
JESTER Mafia-Hooligan Div
Posts: 9,442 Sportster/Buell Model: 1200 R Sportster/Buell Year: 2005
Check the bead closely...........it's probably not seated all the way around.
Deflate it.....spray some soapy water around it and air it back up. There's a little ridge that should be even all the way around.
OR...maybe Will is correct.......Your wheel is bent?
Stuff: YES
5th October 2011
Posts: 2,737 Sportster/Buell Model: 1200c 1980 chopped frame Sportster/Buell Year: 1995 Sportster/Buell Model #2: Ironhead chopper Sportster/Buell Year #2: 1979 Other Motorcycle Model: Nightster GF's Bike Other Motorcycle Year: 2008
if the bead of the tire fully seated?
1979 Ironhead Chopper aka Home Wrecker
1995 1200 on a modified 1980 frame rigid mount swingarm
2008 Nightster GF's bike
Why buy parts, when you can pick up some tools and make something way cooler?
5th October 2011
The bead looks like it is seated correctly, I don't see anything out of the ordinary. Would it be obvious if it was not seated correctly? I took the tire to a well known shop in the area and watched the guy do it.
Man, it better not be a bent wheel. Is there a way the guy could have bent my wheel on the mounting machine? I don't see how it could have been bent otherwise. The weird thing is it was not rubbing just a week or so ago now it is.
Worst case, I could have the stock tire put back on to test I guess.
5th October 2011
lift the front wheel, hold something close to the rim, like a q-tip using the forks to steady yourself and spin the wheel. Watch to see if the rim is moving in and out or if it is the tire that is moving.
it is possible to bend a wheel while mounting a tire. but it could be a defected tire or improper mounting.
there should be a line that runs around the tire that you can see about 1/16 of an inch from the rim, all tires may not have this. it is sometimes hard to tell if the tire is fully seated, so look carefully.
5th October 2011
JESTER MAFIA
Posts: 9,118 Sportster/Buell Model: NRHS 1250-R Sportster/Buell Year: 2005
Check your wheel bearings too.
A Member of The Cell
5th October 2011
I tried this and it looks like the distance between q-tip and wheel stays even, I am hoping it is just the tire. I'll have to take it back to the shop and see if they can re-mount it for me this weekend and check it out in general.
The bead looks even on both sides though I checked that little line and it appears even. It is just like the tire is bulging or something. It rubs almost halfway around the rotation, then the other half turn it does not rub.
What would I look for on the bearings, ovaling?
5th October 2011
to check the bearings,
with the wheel in the forks and torqued down, grab the top of the wheel and see if you have any side to side, or up and down movement. if it does you should feel a slight tap as you take the slack out of the bearings.
also spin the wheel slowly and feel for any grinding or tight spots. it would be best to compress or remove the brake caliper before doing this do you don't confuse brake drag with a bearing problem
5th October 2011
Thanks, I quickly checked the up and down side to side and it is all tight, before I installed the calipers when I had the wheel on I spun it and it felt smooth as well. I am really hoping this is just a tire mounting issue.
| Thread Tools |
| Display Modes |
