Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Engine Conversions
Ironworks Magazine
Dead Creek Cycles
Zippers Performance
Lickscycles
NRHS Performance Long 2
  #661
Old 23rd May 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER MAFIA
Sportster/Buell Model: NRHS 1250-R
Originally Posted by Lenster View Post
...I'm not sure why a loose fuel line would give me lean readings. Anyone have any ideas?
Maybe a bit of air getting in???
A Member of The Cell
Old 23rd May 2012
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
Sure sounds weird to me unless more fuel was pouring onto the ground then into your carb. Almost makes you question the O2 sensor or the maybe something else occured
Link to thread on "Harley Racing" events across the country: http://xlforum.net/vbportal/forums/showthread.php?t=53470
Old 23rd May 2012
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
That's the only thing that comes to my mind! Seems weird though!
Stuff: YES
Old 23rd May 2012
Rico 05R's Avatar
JESTER MAFIA
I agree...after I wrote that, I thought that can't be right. But it was the only thing I could think of that might explain that radical of a change in the AFR.
Old 24th May 2012
Lenster's Avatar
Lenster Lenster is offline
Lenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud of
It is definitely weird. There was no fuel leaking out onto the ground.
The only theory that I have come up with so far is that the (air) leak some how affected the fuel level in the float bowl, and I had to over jet to compensate.
I imagine I'll pick up a few HP with better jetting (and no leaks).
Getting through the Break-In Miles Sucks!
Old 24th May 2012
Rico 05R's Avatar
JESTER MAFIA
I'm sending you another map to look at. After riding the last one I sent you for a while...don't bother with it.
Old 24th May 2012
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really nice
that makes like no sense and you would see that much of a fuel leak out, but on the other hand it could pull more fuel now instead of air have you driven the bike since you have fixed this i wonder if you have a intake leak when its hot and when its cold it seals back up some what .that would give you a wearied reading.
Old 24th May 2012
Gcram399's Avatar
Gcram399 Gcram399 is online now
Sportster/Buell Model: Hammer 1250 Hugger
Gcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant future
Can the intake vacume create enough internal carburator negative pressure to actually cause aeration fof the fuel in the bowl? If it can, then the fuel being fed through the jets would also be a bit leaner.
Just trying to think it through?
Support the forum because the
George
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
Old 24th May 2012
Bob s hog's Avatar
yes it can and know that he has a good seal i think it will draw more fuel kinda like a venturi effect
Old 24th May 2012
Lenster's Avatar
Thanks brother! Always up for trying new maps.
As soon as I fixed the loose fitting my AFR became WAY rich. I have ridden it quite a bit after the fix and its always rich so I'm assuming there isn't an intake leak. I also think you're onto something about it being able to draw more fuel, maybe because the float bowl was over vented with the leak, the atmospheric pressure couldn't push the proper amount of fuel.
