NedNimrod, jduffy01, LVBOATDOC (61), glef (56), Dogsbd (51), darkcustom (36), jon8641 (29)
Foxcreek Leather
Foxcreek Leather
Ironworks Magazine
Sky Smith Insurance
Old 26th December 2011
Slashkutt Slashkutt is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: HVA TE610
Other Motorcycle Year: 1994
Slashkutt is on a distinguished roadSlashkutt is on a distinguished road
Default Washer on the kick start pedal ?
There an asymmetrical - rats, a washer that don't look right... - washer for the pedal to stay fairly locked in folded position. I have tried all combinations, that is all 4 sides against the kick start, AND above as well as under where the pedal engages the shaft. Anyone know how the darn thing is supposed to be fitted ? Does it require the bushing to ride high or flush ? Thanks !
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH w/1200kit
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Pan/Shovel
Other Motorcycle Year: 1968
rivethog has disabled reputation
If it's an aftermarket, it probably ain't made correctly. The bushing should be a little wider than the pedal boss, and the hole in the spring washer should be large enough for the bushing to go through it (the hole on most aftermarket spring washers is too small for the bushing to go through) . On most older H-D's I've worked on, in an effort to keep the pedal "tight", the PO's had tightened down the pedal bolt so tight that the kicker arm became deformed and a new stock length bushing wouldn't fit without spreading the kicker arm.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Yeah, I'm afraid that' what the PO did to this bolt, that is crank it down to no avail. The bushing looks mashed... It makes sense w/ your explanation, oh well...
Thanks anyhoot!
