Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
CV Performance
Speedway Instruments
Licks Holiday
Old 4th January 2012
Senior Bike Builder
Default Turbo Head: 883 or 1200 That Much Better?
Looking for a 883 or 1200 EFI to do a turbo project on and was wondering about the head.
*Equal sized valves are wanted.
Not sure about squish bands or ideal chamber shape.
*The pistons will eventually be deep dish thick top, so yes, the head's chamber should compliment the piston.
*Compression target is 8:1.
*2 plugs per cylinder.
*Welded up floors? Just threw this in on a whim. Probably a waste of money.
This is still in the planning stage, bike not purchased yet so there is wiggle room but a '07 883R EFI is the current favorite.
Ideas???
JasonSarratt's Avatar
JasonSarratt JasonSarratt is online now
Turbo Mafia R&D
Sportster/Buell Model: Turbo XL Sidecar
JasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud of
I'm currently working with someone on a 883 turbo kit for the street... I think the 883 is a great build project. Lower cost to buy, lots of fun to be had, and if you ever decide to go with more you can always upgrade to a 1250 conversion... I'm going to get with Dan and try the 883/1250 pistons in my bike to see if I like the lower compression...
Will report back on both projects
