15th February 2012
Posts: 631 Sportster/Buell Model: 883R Sportster/Buell Year: 2003 Sportster/Buell Model #2: XLCH 1000 Sportster/Buell Year #2: 1972
Ebay Steering Damper - Anyone Buy One Yet?
Hey everyone saw these on ebay and was thinking about picking one up on payday. Has anyone purchased one of these already? Was wondering about the build quality.
http://www.ebay.com/itm/200648096355...84.m1423.l2649
"WFO From The Get Go"
1972 1000 XLCH
2003 883R
15th February 2012
Posts: 1,064 Sportster/Buell Model: XL1200N Sportster/Buell Year: 2008
I know there's someone on here that recommended it but I don't remember who so here's a bump..
15th February 2012
Posts: 5,667 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
I'd spend my money on something name brand. There is no way to determine the quality without knowing the manufacturer.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
15th February 2012
Posts: 1,598 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
I copy this review from BKrider site.
Strengths: Small and discreet, good range of motion so doesnt hit any part of the bike, doesnt look out of place so it looks great, easy to install, has a wide range of tension from simply turning the adjustment screw which allows very little damping to very high tension damping.
Weaknesses: Does not come in BLACK! Could use single spacers should have various sizes provided instead of just multiple washers. Slight moisture around bar as if there is a light leak. Not easy to tear down for rebuild for powder coating and/or maintenance. Unknown what tool is needed to remove end caps. Unknown fluid or seals to rebuild when necessary.
Summary: This little damper looks great on my 09 Dyna FXDF and was necessary as I installed an aftermarket fairing that weighs in over 30lb. The damper looks good but doesnt come in black, which is a negative for my blacked out Dyna. Although it can be powder coated it would be nice if it could be torn down easily, but that is not the case, seems a special tool is required for the end caps. BUT if torn down for powder coating or maintenance then the major issue arises of what fluid and seals to use as there is no documentation. BKRider.com is good enough to research it for me but regardless if you ever want to PC the unit at some point or not eventually the unit will need new fluid due to wear and tear or simply to refill if a slight amount is lost over time. Hence the need to know what tool is needed to tear down, what hydraulic fluid is correct and the right seals to prevent future leakage in order to maintain the unit. Overall though this damper works well, is small and affordably priced.
15th February 2012
Posts: 12,744 Sportster/Buell Model: xl1218rr turbo Sportster/Buell Year: 1993
I have a daytona that I have had on my bike since 1995 and it still works great. That being said, the mount design is shizzz on the Daytona that I bought. You can see it flex and bend and I am surprised it did not break off long ago. I may order this because I prefer the position and design of the mounting system. I will have to see. Looks like a nice unit.
Spoiled but definitely not rotten. Started life as a black 1993, 1200 Now-1218, Home ported 2009 FI heads, SE 551 cams, Aerocharger variable vane turbo. Dyna2Ki, JMC aluminum swingarm, Chainsikle custom mid forward controls, GBC inverted front end, 3 degree wide-glide trees and 5 degree raked cups. 18x5.5 fatspoke rear with 150/60 and 21x3.5 with 120/70.
15th February 2012
Amateur Hour
Posts: 3,146 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
no name products are on ebay for a reason.....half azzed stuff and service.....support a vendor on here of buy local from your community.
15th February 2012
Mad I would normally agree with you but I doubt there is a single U.S. made variant of that part. You buy that same item locally and pay twice as much, more expensive does not make it better.
15th February 2012
Posts: 387 Sportster/Buell Model: Nightster Sportster/Buell Year: 2008
I got one from BKrider for the wife's Sporty trike but it didn't fit with the crash bar and at the time I was too lazy to modify it to make it fit. It looked well made and operated as stated. I can not comment on performance on the road.
"For those who care, I do not"
15th February 2012
15th February 2012
Posts: 1,432 Sportster/Buell Model: White Hot Denim XR1200X Sportster/Buell Year: 2011
I used to have a WP suspension steering damper on my racebike. It saved my a** a few times and was built to last.
| Thread Tools |
| Display Modes |
