The Sportster and Buell Motorcycle Forum Get Lowered Sportster
Figure Machine
Get Lowered
Get Lowered
Old 13th March 2012
TheJack's Avatar
TheJack TheJack is offline
Sportster/Buell Year: 77
TheJack is an unknown quantity at this point
Default Need some 77 ironhead rear brake help
I`v bin reading threads about the 2 elements on the brake light being lit. i have the same problem. looked over everything and found this. ok, it wont let me post the pic cuz i`m new.
the wires were taped together to make it look like the brakes were on but once i untaped the connection the lights shut off. so yeah, i need a switch, but i then had no tail light. could someone point me in the right direction? and could someone post a link to a new rear brake switch? everything else works. i`m just having problems with the light.
Old 13th March 2012
TheJack's Avatar
Old 13th March 2012
Same switch as in the front brake lever. Do not replace with a $5 POS. Spend the $25 and get the Harley Davidson one. Or order this one from eBay ...
http://www.ebay.com/itm/320855257805...84.m1423.l2649
Old 13th March 2012
TheJack's Avatar
Thanks a lot Mic.
Old 7th May 2012
TheJack's Avatar
now when i turn the headlight on the rear blinkers dont work. when the headlight is off all is good. any suggestions? everything was working i just dont know what i did wrong.
Old 7th May 2012
In which areas did you make changes?: headlite bucket, right handlebar switches, left handlebar switches, ... ?
Old 7th May 2012
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about
One problem I see is that those two wires should be one red and one orange. Looks like you've got black and white. Better trace them back and see if they go to red and orange.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Old 7th May 2012
TheJack's Avatar
the only changes was risers and struts. i had the rear fender off / disconnecting rear turn signals and rear light. i`m all but 100% positive the wiring is the way it was when it worked. i did take off the speedometer and disconnected the 2 wires that came from it. 1 ground and 1 power.
Old 7th May 2012
TheJack's Avatar
Brake works fine now 2007Low. i just have a problem with the rear blinkers when the head light is on. fronts work just not the rear.
Old 7th May 2012
2007Low's Avatar
So what about a rear brake light switch? Did you put one on or are those two wires still disconnected?
