Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Tanjis Kahn, george (58), mwndragon (56), XxValDeexX (32), ELPYRO (31)
Progressive Suspension
Licks Holiday
Biltwell
Ricor Shocks
Old 14th March 2012
michaelm101 michaelm101 is offline
michaelm101 is an unknown quantity at this point
Default Gas Tank Info Needed
I have the tank off and have labored to drain it.
I noticed that fuel does not run out of the petcock like I've been accustomed to-- so I had to screw the whole contraption off the tank. Then the gas kind of got all over because I couldn't pull the whole filter through the hole-- and I didn't want to force it and end up busting it.
Is this the way it's designed, or should I just push and force that filter thing through?
Thx.
Old 14th March 2012
bustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of light
yea, the nylon strainer on mine was like you described. i just siphoned my tank with a hose before pulling the pet.
Old 14th March 2012
Were you able to pull the whole petcock out along with the strainer?
