19th July 2012
Posts: 4,659 Sportster/Buell Model: Hammer 1250 Hugger Sportster/Buell Year: 1997
Originally Posted by Rico 05R
Most folks have their mixture screw at 2.5 turns out, that may fix the carb fart issue. I have several other maps that are more aggressive if you want to try them.
What jetting is he running? My CV had a mid throttle fart with 1 washer under the stock needle, a 185 jet and was turned out 2.5 turns on the IMS. When the  Dynotuned mine he put in a Dynojet needle with the clip on the 3rd slot, put in a 180 jet and turned it out 3.5 turns.
Even with the timing as screwed up as he had it, the carb farts were totally gone even when cold and the throttle response across the RPM band was much smoother and felt more aggressive.
Just a thought.......
Support the forum because the
George
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
19th July 2012
Posts: 156 Sportster/Buell Model: 883c/1203xb Sportster/Buell Year: 2006 Sportster/Buell Model #2: 1994 XL1200 Other Motorcycle Model: 1998 Heritage ST
I have a 45 slow and 180 main. The needle is in the stock position
[IMG]http://i1098.photobucket.com/albums/g374/proturn/Bumper-Sticker3.jpg[/IMG]
[url]www.tpemachine.com[/url]
[I]Manufacturer of precision components[/I]
Matt Smith~Owner
1-763-856-8355
1-888-856-0984 toll free fax
email [U]theprecisionedgemachine@yahoo.com[/U]
19th July 2012
JESTER MAFIA
Posts: 9,147 Sportster/Buell Model: NRHS 1250-R Sportster/Buell Year: 2005
I think another half to a full turn out on the mix will cure those farts. Maps are in your email sir.
A Member of The Cell
19th July 2012
Jester Mafia
Posts: 1,538 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2004 Other Motorcycle Model: CB750k SOHC Other Motorcycle Year: 1977
Also try running a colder plug if you get ping'n
3rd August 2012
JESTER MAFIA
After a ton of tweaking and riding, I believe I now have the perfect 1250 map. If anybody wants it, just let me know.
3rd August 2012
XLFR
Posts: 2,191 Sportster/Buell Model: XL1200C Sportster/Buell Year: 04
Me! Pick me! hehe I'd like to take a look at it. Thats all I can really do with it right now anyway. My bike is a few weeks out from being back together. Thanks Rick.
3rd August 2012
JESTER MAFIA
I already sent it to you.
I also sent it to Rejean, Lenster, and Derek. If anyone else with a big bore and a TC 88A wants it, let me know. I think you're going to like this one guys.
4th August 2012
Jester Mafia
Posts: 605 Sportster/Buell Model: 1200C Sportster/Buell Year: 2006
I put about 100 miles on the revised version of the Jester III Rico sent me a few days ago and am happy to report that it sets a new standard for Sportster refinement. I had recently been experimenting with bumping the timing up on the original Jester III. I ran it with the initial timing set at 7 for a while. I thought maybe there was slight increase in power, but finally decided that the motor was just twitchier and ran less smoothly. It was something I felt more than heard, but I was concerned about detonation, so I backed it down to 6 and the motor was clearly more happy. We've had relatively high humidity for weeks and I don't remember the last time the dewpoint was below 70 degrees. Maybe winter will be a better time to advance the timing. I was all set to put it back in the neutral 5 position for comparison when Rico sent me the revised version and it is very smooth with plenty of power. It's great to be able to twist the throttle two-up while changing lanes in traffic and feel the bike leap forward like a thoroughbred chomping at the bit. Folks, I think we have a winner!
4th August 2012
JESTER MAFIA
Thanks for the feedback.
4th August 2012
Jester Mafia
Posts: 8,602 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 Other Motorcycle Year: 2012
I'll just stay with the 8-5-7-0 Nomad for now
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
| Thread Tools |
| Display Modes |
