13th January 2008
Posts: 40 Sportster/Buell Model: 883 custom Sportster/Buell Year: 2004
question about 1200 conversion..
when you go from an 883 to a 1200 conversion i understand how the displacement is increased, but what about the gear ratio and such?...my 883 has a stage two kit and it runs good and i can feel the higher rpms arounnd 80 mph or so....question...with the 1200 kit will i still feel the same rpm feeling at 80 mph? ...i may have more power and get to 80 faster with the 1200 kit ,but wont i still have the same drive train and the bike will still have the same rpm ratios thru the gears?...
13th January 2008
Yep, same rpm at the same speed unless you change the gear ratio. Changing the front sprocket to a larger diameter will drop the rpm. I considered the 27-tooth to 29-tooth sprocket change ('03 and earlier; 30-tooth, I believe for '04 and later) as an extra gear.
13th January 2008
Posts: 287 Sportster/Buell Model: 2009 Dyna Street Bob Sportster/Buell Year: 2009
not sure i understand this question very well.....but the guy that lives across the street did his 883 to a 1200 and he has no problems.......his bike runs beautifully..........i wish i could help....good luck man
13th January 2008
Brass Nut
Posts: 30,439 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
Yes, you will, and some see this as an advantage because you'll still have the lower gearing of an 883, which will make the bike accelerate faster than a stock 1200 could.
The downside is that you'll be turning higher rpms at highway speeds, which stresses the engine more. There are questions as to whether this causes higher oil temps and higher oil consumption. Some folks who convert their 883s to 1200s also change the gearing to be more like the 1200 ratios.
To get exactly the same gearing as a 1200 would need the engine sprocket and the primary chain to be changed, as well as the transmission sprocket. I think most people just change the transmisison sprocket.
Folkie
'The green machine'
13th January 2008
Posts: 2,402 Sportster/Buell Model: Sold Sportster/Buell Year: 2005
All that changes with a basic conversion is the cylinders are bored larger and matching larger pistons are installed. Everything else on the bike remains as it was.
I like mine with 883 gearing. It goes as fast as I want (115mph) and maintains a low 1st gear for slow going when needed. I can cruise at 90mph, but 70-80mph is my usual highway speed so it's fine.
If you have somewhere you can comfortably or legally cruise at 90+ then a re-gear might be in order. I don't want to lose my license to drive and ride so lower gearing is another plus for me, and the acceleration is GREAT!
2005 Black 883XL / NRHS 1200, 9.5:1 Comp, .497 Cams, SE A/C & Pipes, Jagg oil cooler
_________________
Don't throw your pearls to swine! They will trample the pearls, then turn and attack you.
Well ... that explains a lot.
13th January 2008
thanks for the feedback...i think i would have to ride one for comparision before i would make the change..in the meantime i will do the front pully change...
13th January 2008
Posts: 2,841 Sportster/Buell Model: 2001 883 Custom
True that. My conversion plus has all the power and roar I can use in every day riding. I cruise at 70- 80 mph on the freeway. But even that doesn't last long . The wind will beat you to death if you sustain much over 70mph. anyway. Most of the guys I know with performance Sportys gear them DOWN.
."....no time for memorandums now. Go ahead! Liberty and independence forever!"
The last entry in Davy Crocketts diary, The Alamo 1836
13th January 2008
Desertfox, I noticed you have a solid mount. What did the conversoin do to your motor's vibrations? I assume you went with light weight forged alloy pistons as I and most do. The vibes didn't increase on my rubbermount.
13th January 2008
Vibration, at least percieved vibration actually seemed to decrease somewhat. Especially at freeway speeds. When it was an 883 anything over 70 mph had vision blurring vibration. Seems to run MUCH smoother especially at 70mph+. Yep, I went with forged reverse dish pistons.
16th January 2008
Posts: 1,011 Sportster/Buell Model: XL1200 Sportster/Buell Year: 2001 Other Motorcycle Model: HD Ultra Classic Other Motorcycle Year: 2009
Went to the 29T after the 1200 conversion ... Was fun for a couple weeks stoplight to stoplight but got old quick...
 ***Jayson*** 2001 XL883>1200 Stage 1 SE AC
| Thread Tools |
| Display Modes |
