The Sportster and Buell Motorcycle Forum Licks Tanklift
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Ironworks Magazine
Energy One Clutches
Fix My Hog
BIKE BUILDER
Old 11th April 2012
Nytstr's Avatar
Nytstr Nytstr is offline
Turbo Mafia Test Rider
Sportster/Buell Model: XL1250NT LSR #1171
Sportster/Buell Model #2: XL1200RT
Nytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to beholdNytstr is a splendid one to behold
Default Hellcat Hellraiser install
I received my custom turbo kit from Jason Sarratt at Hellcat Customs today!
So to begin, my install is a bit different from HandOverFist's. Mine was a 1200, now it has a 1250 kit from NRHS using dished forged pistons for a lower CR which will allow for running more boost. Also, Jason did a little 'secret sauce' routine on the heads and intake. Still running stock cams, lifters and valves, but now it has new Cometic valve guide seals as the stock ones were leaking.
I really had hoped to finish the install this evening, but had a crappy night and am very tired, so I'm going to finish up tomorrow evening. So far, this is what I've accomplished:
I had received the heads, intake and cam cover last week, so they are already installed and the engine is all ready for the turbo kit:
Turbo Mafia Charter Member
I'm not crazy, I'm sanity challenged.
Please support my rookie Bonneville attempt!
http://www.gofundme.com/AsotinLandSpeedRacer
The Last Truly Amateur American Racing!
Old 11th April 2012
Nytstr's Avatar
Unpacked the box to reveal the goodies inside:
Old 11th April 2012
Nytstr's Avatar
First, the intake support bracket is mounted using the screw provided, and breather bolts are put in just finger tight at first. Then the screw is torqued down, and the rear breather bolt is also tightened. (Sorry, Jason, I just had to use my fancy breather bolts - but they're plugged because I did the Deimus breather mod):
Old 11th April 2012
Nytstr's Avatar
Next, the dump pipe with support bracket is temporarily bolted up to the turbo housing:
Old 11th April 2012
Nytstr's Avatar
After positioning the turbo with attached dump pipe, it is held on using the front breather bolt. The plenum is attached to the intake using a standard intake gasket, after slipping the silicone intake hose onto the cool side of the turbo. Oil lines are also routed and attached:
Old 11th April 2012
Nytstr's Avatar
Next I snugged up the oil lines, clamped the silicone hose, put on the plenum cover and am now ready to remove the dump pipe, leaving the turbo hanging from the hose so the exhaust header can be installed tomorrow:
So far I've got 1 hour total invested, and the only issue was the small oil line fitting - the J-B Kwik didn't set up, so I removed it and cleaned it up and reinstalled it with some red loctite. Might have to go back and use some fresh J-B so it isn't facing forward.
Old 11th April 2012
JasonSarratt's Avatar
JasonSarratt JasonSarratt is offline
Sportster/Buell Model: Turbo XL Sidecar
JasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud of
Making progress.... Can't wait to see what a 1250 can do now
Old 11th April 2012
DK Custom's Avatar
Sportster/Buell Model: 883L
DK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to beholdDK Custom is a splendid one to behold
Very cool...gonna be watching this.
Old 11th April 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
Looking good so far Nytstr - we'll be waiting for an update!
Old 11th April 2012
steelworker's Avatar
steelworker steelworker is online now
Do you drill and tap into the oil galleries along the top of the cam cover to get an oil feed to the turbo? If so, then surely it takes more than an hour to reach the stage you're at, as you wouldn't drill and tap the cover in situ. Would you??!!
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
