The Sportster and Buell Motorcycle Forum Figure Machine
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Ricor Shocks
Zippers Performance
Old 16th April 2012
Tyberius's Avatar
Tyberius Tyberius is offline
Sportster/Buell Model: 883C
Tyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really niceTyberius is just really nice
Default Whittlebeast Hybrid Shock Build
This is a thread to document the Whittlebeast Hybrid Shock build.
I had wanted to make the hybrid shocks, and had searched for some build threads, but I hadn't found any that showed clear pictures, so I decided to document my attempt for those less adventurous than I.
I couldn't get a shock tool, so I decided to use band clamps.
Look! I probably should have loosened the adjusters
08 883c commuter bike, mid-controls (including shift peg), superbrace, rifle roadster fairing w/ tall shield, national cycle hand deflectors, h-d front signal relocators, mustang wide touring w/driver's backrest, passenger pillion and passenger backrest, h-d throw-overs w/drag specialties supports, sissy bar, NRHS Hurricane Oil Filter, oil temp gauge, deltran battery tender plus, otc lift, HD Handlebar clip , HD garage door opener, WB hybrids
Old 16th April 2012
Tyberius's Avatar
Tightening up.
This position will end up being too close together. I will have to move the clamps farther apart to be able to release the pressure on the top clip.
Old 16th April 2012
Tyberius's Avatar
Reversed the clamp and tightened.
Old 16th April 2012
Tyberius's Avatar
Tension is getting slowly released.
Old 16th April 2012
Tyberius's Avatar
Clip and cover off.
Old 16th April 2012
Tyberius's Avatar
Same thing again for the C shock.
Old 16th April 2012
Tyberius's Avatar
Checking the length. The C shock is on the left and the R shock is on the right.
Spacer cut.
Spacer inside what will be lower cover.
Old 16th April 2012
Tyberius's Avatar
Shock going back together.
Here I caught the plunger of the shock on the clamps as I was reassembling and had thought I had to rework the clamp, because I was not getting enough spring compression to clear the eye. I finally saw what I had done and slipped the shock back together.
Shock complete.
Old 16th April 2012
Tyberius's Avatar
Side by side with the R shock.
Old 16th April 2012
Tyberius's Avatar
Back on the bike.
