19th April 2012
Posts: 26 Sportster/Buell Model: 1000cc XLH Sportster/Buell Year: 1981
What oil do you use with Barnett Kevlars?
Alright I am trying to figure out what oil I should use with my new kevlar clutches and discs that came in the mail from Barnett.
They say do not use Formula Plus but recommend Type 'F' ATF.
I don't want to use ATF or Formula Plus even though some people are using them.
I did a search on this matter but I want to hear what you guys are using for your Barnett Kevlars other than those two.
19th April 2012
Posts: 874 Sportster/Buell Model: XLCH Sportster/Buell Year: 1969 Sportster/Buell Model #2: XLR Tribute Sportster/Buell Year #2: 1962 Other Motorcycle Model: XLH Other Motorcycle Year: 1968
I am not sure I understand. You don't want to use what they advise against or what they recommend?
For what it is worth I am running either ATF or Formula + in each of my 3 converted dry clutches (62, 68, 69) and am pleased with the results. Engine oil seemed to gum and stick the plates when sitting.
Choices are: ATF, Formula + (or dirt bike wet clutch and trans lube), engine oil...
Lets not turn this into a Transfer Valve discussion, but I think your 81 should have the covered by design.
19th April 2012
Senior Master Bike Builder
Posts: 2,164 Sportster/Buell Model: XLH Sportster/Buell Year: 1987 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1991 Other Motorcycle Model: Sportster XLH Other Motorcycle Year: 1995
Soak them in whatever you plan to run in there.
Type F is being used by the old timers and they like it.
20-50 SYN is an option.
Sam
19th April 2012
Turbo Mafia Test Pilot
Posts: 1,068 Sportster/Buell Model: XL1250NT LSR #1171 Sportster/Buell Year: 2007 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2007
B&M Trick Shift
Sent from my SPH-D700 using Tapatalk 2
Turbo Mafia Charter Member
Authorized Hellcat Customs Test Rider
I'm not crazy, I'm sanity challenged.
Please support my rookie Bonneville attempt!
http://www.gofundme.com/AsotinLandSpeedRacer
The Last Truly Amateur American Racing!
19th April 2012
Posts: 4,104 Sportster/Buell Model: Ironhead XLH Sportster Sportster/Buell Year: 1978 Sportster/Buell Model #2: Ironhead XLT Sportster Sportster/Buell Year #2: 1977 Other Motorcycle Model: Honda CBX 1000 Other Motorcycle Year: 1979
Don't use ATF as recommended by Barnett!! I did when I put the Kevlar plates in my '77 and although the clutch action was excellent, I found the tranny became very notchy and harder to shift than when running Formula +. When I drained the ATF, it had a lot of fine shiny particles in it. I put in Formula + and the clutch action is still excellent and the tranny is shifting smoothly again.
Eric
19th April 2012
Posts: 121 Sportster/Buell Model: xlch Sportster/Buell Year: 1968 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1971 Other Motorcycle Model: xlh Other Motorcycle Year: 1972
90 wt gear oil and engine gets strt 60 with lucas oil treatment i want whatever stands up to the heat the most!
19th April 2012
I want to use whatever is best for my transmission and clutches.
Here are my concerns:
I don't want to use ATF because of possible issues with leaks and I am not sure how these old ironhead transmissions will do with it as far as lubricating the bearings goes.
Does anyone know if using type "F" ATF is adequate enough for these old transmissions from personal experience?
I didn't want to use formula plus because Barnett says not to use it.
I found some info from another forum were someone talked to Barnett and they said that Formula Plus can be used but the problem is that it gums up causing the plates to stick together which makes it harder to find neutral. If there is nothing wrong with using it other than finding neutral will be harder then I don't see any problem with throwing it in.
My question is does the gumming up have a negative effect on the kevlar clutch/ transmission longevity? If not then I will just stick with formula plus.
20th April 2012
Posts: 334 Sportster/Buell Model: XLHC Sportster/Buell Year: 1967
I run atf in mine like Barnett recommends but it is hard to shift... I put atf in my shovel and it is ok
20th April 2012
Posts: 3,329 Sportster/Buell Model: XLCH Sportster/Buell Year: 1969 Sportster/Buell Model #2: 1966 XLCH Other Motorcycle Model: BMW Twin Other Motorcycle Year: 82
I renaged on Formula + at first, but it works so well I stayed with it......
Cycle World Oct 1962:
20th April 2012
Posts: 1,575 Sportster/Buell Model: FLCH Sportster/Buell Year: 61 Sportster/Buell Model #2: XLCH Kit Bike Sportster/Buell Year #2: 60
I posted this question on the J&P Forum a while back:
http://community.jpcycles.com/forums...94.aspx#254294
I have been running the HD sport translube. Works great.
(until recently... I've been leaking motor oil into the primary so I just run motor oil for now until I get that fixed...which I am currently working on)
Scott
'61 'CH
'60 'CH
| Thread Tools |
| Display Modes |
