The Sportster and Buell Motorcycle Forum GL Sporster
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Electrical and Ignition
Tanjis Kahn, george (58), mwndragon (56), XxValDeexX (32), ELPYRO (31)
Biltwell
Figure Machine
Lickscycles
Licks Cycles
  #111
Old 12th June 2012
sportsterdoc's Avatar
Other Motorcycle Model: Triumph Bonneville
sportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to all
Last night, when I was apparently brain dead, I was sure the motor rotated CW. Since I am presently Sportsterless, I was not able to just go look. So, I emailed Art Northrup, Jr. and he sent me this link. I was only 1/2 right and thus the misdirection on the timing plate rotation.
http://www.animatedpiston.com/Evo.htm
Old 12th June 2012
tara's Avatar
tara tara is offline
Sportster/Buell Model: 1200 xl
Sportster/Buell Year: 1987
tara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura abouttara has a spectacular aura about
Originally Posted by sportsterdoc View Post
Steelworker: Thanks for the correction.
Tara: Was the plate somewhat in the middle?
there are two openings in the pick up : one round and one long. it was bolt on the long one but close to the round one.
1986 frame - 1997 1200 engine stage 1.5 - N2 cams- single fire Accel - Crane hi 4 - big sucker - 23 T sprocket 48 T - Ohlins #3#3 13 1/4 - showa 35 mm Progressive spring - all brake system by Performance Machine second motor 86 4 speed 883conver 10.5 1200 V8 cams 1200 heads - tuned CV cards by killer motorcycle product -
Old 12th June 2012
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
It's all a matter of perspective... A train can be coming or going, depending on where you are standing when looking at it.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
Old 12th June 2012
LOL...well, I was 1/2 correct, the motor does turn CW, but the cam about which points or pickup coils get their fire signal are CCW, therefore Tara was correct about CW on the plate to advance timing. Work is picking up, got to take a hiatus from the forum for a bit. I think once Tara gets her timing dialed in (if it is not already), she will be running good.
Old 14th June 2012
tara's Avatar
so doc and wedge, these are the news :
the odd sound was my primary chain, much too tight : the lesson is that i will now tight when hot, not cold
i put some more advance on the timing turning slightly cw the pick up, and it comes right at the end of the slot : result is idle was much better, but start pinging when open throttle, so i put it back in original position
Old 14th June 2012
wedge's Avatar
Whitworth Products
Well, now that you know that it pings when you advance it, then all you need to do is play with it until you can advance it as far as possible without it pinging, then maybe back it off a degree.
Old 14th June 2012
Glad you found the primary chain noise, before the chain stretched
What you did for the timing is what I would do...as far advanced as possible, without pinging. If you only backed off as much as you needed to, you are at your optimum timing: Maximum burn time for efficiency and power.
The only time that method is not useful is tuning at higher altitude. I could not have done that when I lived in Flagstaff (almost 7,000 feet), as it would have pinged at lower altitudes. When I did it at 900 feet, it was never an issue.
This is also based upon consistent fuel grade. You could not time that way and then run lower octane fuel.
How does the bike now feel? Good over all response?
Old 14th June 2012
LOL, our minds were on the exact same track, at the same time!
Almost got a new bike, yesterday, but the dealer sold it while I was making the inquiry: 2008 (yep, EFI...got to eat my words, sometimes), just under 10K miles for $5,295 (standard height 883). Looked very stock (what I want to start with) and very clean...even good tires. Lots of customs available, but not mid-controls. I took my truck to my middle daughter in Colorado, early May...so, I now have room in the garage, next to my wife's SUV...
Been checking dealers in Ventura County, CA and Las Vegas Valley, NV...some don't even have a used Sportster. Even checked Cycle Trader and Craig's List. One's of interest on the forum are either too far away or posted so long ago they are probably sold.
Old 14th June 2012
wedge's Avatar
Whitworth Products
Well, ya know what they say (whoever they are)... Great minds...
Problem is that the same logic applies to IDIOTS too
I could help you pull that EFI off and throw it in the trash (or we could have a bon-fire) with it as the centerpiece?
Old 14th June 2012
wedge's Avatar
Whitworth Products
Oh, timing chain... Get the bike HOT...
Then adjust it while the bike is idling. Tighten it until it starts to complain (listen very close for this) then back it off 1/4 turn and lock it down.
