The Sportster and Buell Motorcycle Forum Get Lowered Sportster
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
Licks Cycles
Figure Machine
NRHS Performance Long 2
Biltwell
Old 5th June 2012
jared..mann jared..mann is offline
Sportster/Buell Model: Custom
jared..mann is an unknown quantity at this point
Default Engine help!!!!!!!
I am in the military and this is my only transportation.
I have had this biek for 4 years with NO problems! I did an engine bore to 1212 with NRHS. Everything great! Rode it to work yesterday, and home NO problems!
Went out this morning to go to work, and the engine will not move! Oil in tank never seen a oil pressure light or anythying. in Netrual engine will not move?!?!?!? Think it is a tranny issue? ANY HELP PLEASE!!!
Old 5th June 2012
OK?!?!?!?! I pulled the plugs squirted some WD40 in the cylidners, put it in 5th gear and the motor moved liked nothing happened. I put the plugs back in, started right up no probs???? WTF!?!
Old 5th June 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice1250IRON is just really nice
when you say it won't move you need to give a little more info. do you mean in neutral it won't turn over but you can hear starter trying or just a click or nothing at all?
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 5th June 2012
In Neutral it will move, but when I tried to hit the starter in neutral it just clicked. It seemed like it was stopping the starting, no noise happened after that. I rode it a few times today, I think I freaked out a little early. I think my starter is going bad, or I had a bad connection from the battery. I tightened up the connections when I got home from work.
How do I know if I am about to shit a starter? Also are they rebuildable?
Old 5th June 2012
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
khaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud of
Check both ends of the battery cables. You are describing a battery issue.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 5th June 2012
sportsterdoc's Avatar
Bike Builder
Other Motorcycle Model: Triumph Bonneville
sportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to all
1. What is battery voltage, key off? A $30 Radio Shack auto-ranging digital multimeter will answer that.
2. What is battery voltage, key on?
3. What is the battery voltage while cranking?
4. As khaskins already posted, have you checked the integrity of both ends of both battery cables?
Old 6th June 2012
Great ideas guys! I will get on that after this weekend. I have to go out for training this weekend I will be back Monday!
Old 10th June 2012
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
Like Karl said........it's cables........nothing wrong with the motor.!
Stuff: YES
Old 10th June 2012
racerwill's Avatar
Super Moderacer
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
racerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant future
Cool
agreed but could also be a battery going bad...... not the engine tho
Ww
master wizard
RIP Mr Jimi
Old 10th June 2012
Bike Builder
At 11 years old, it could be battery and/or cables
Wish everyone with a potential (pun intended) electrical problem had a voltmeter and made a few basic reads.
