Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Electrical and Ignition
Get Lowered
Sky Smith Insurance
NRHS
speed senor, speedo, speedometer
Old 12th June 2012
Slicks_95 Slicks_95 is offline
Sportster/Buell Model: 883 Deluxe
Slicks_95 is an unknown quantity at this point
Default My speedo issue is driving me crazy!
Hello everbody names Chad and I have a 95 Sporster 883 with a 1200 kit . My bike runs great but when I. Bought it last month the speedo didn't work . I read a lot on the forums and my symptoms where pointing towards the sensor. The needle woudnt move and the trip odo said 1.2 and woudnt change to anything but a blank screen. My turn signals cancelled half the time so I figured senor... well that didn't make the speedo work so I replaced it with a new drag speicalties white face mini elec speedo. Its hooked up the needle moves when u turn on the bike and goes all the way up and back down but will not move after that. The calibration says to drive exaxctly one mile in calibrtion mode so it can record the pulses but the pulse meter never leaves zero. I switched the wires around in case they were backwards but no luck . Any help wud be appreciated.
Old 12th June 2012
WinterWheel's Avatar
WinterWheel WinterWheel is offline
Freedom Lover
WinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to beholdWinterWheel is a splendid one to behold
Welcome from Canada's Capital!
I won't pretend to know what the problem is precisely, but a major complaint with the speedometer is a bad ground. LuxBlue and Lenster have had extensive experience with grounding issues. There's a couple of threads.
I've had it happen once to me, but after shutting down for a while, it never did it again. I'm now using a Dakota Digital. (Love it)
Again, not saying this is what's wrong. Just giving you a starting point.
I don't want to simply be alive. I want to feel alive!
I prefer to ride the Stallion, not the Plow horse!
Old 12th June 2012
bustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of lightbustert is a glorious beacon of light
did the new speedo come with its own sensor?
Old 13th June 2012
denguy denguy is offline
denguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enough
My 95 1200 speedo finally died, switched to a $75 "Demoncycle".
HD dealer wanted $500 for a knew one. Sure do wish HD had stayed with the cable drive. If it ain't broke don't fix it.
Old 13th June 2012
veight veight is offline
veight is an unknown quantity at this point
hook up a voltmeter to the sensor wires. I have black,red and white. check for power black and red. then power white(sensor wire) and black and spin the rear wheel in gear you should get a pulse reading on the meter . sorry i do not know what color the stock wirers are. hope this helps.
Old 13th June 2012
No I bought a new one first from JP than the speedo from D.K. . I'm going to get a volt meter after work and test everything ill post when I'm done.
Old 15th June 2012
cody.adams cody.adams is offline
cody.adams is an unknown quantity at this point
I am having a similar problem. Today on the way home speedo fell from 70mph to 0. After exiting highway bike died at a stoplight while clutched and in 1st gear. Started back with on first try. After I got home I keyed it on and off a couple times and the check engine light came on and off twice within 10 seconds prior to starting. Then it idled real choppy for a bit them quit after I reved it couple times.
The bike is a 2011 '48, I just got a coil key relocation installed 2 weeks ago.
Old 16th June 2012
Well yesterday I bought a volt meter and tested the new speed sensor and was not getting any voltage from the wires. So I put the old onee back in and it worked just fine with the new speedo. So my problem was the factory speedo. Now I have a new workinng speedo but the turn signals don't cancel at all. I had to disconnect the wiring harness that ha the wires for the turn signals so that might have sumthing to do with it. Oh well at least I know how fast I'm goin ... thanks everybody for the help.
