19th June 2012
Posts: 12 Sportster/Buell Model: 1200C Sportster/Buell Year: 2005
New ignition module advise?
My 05 1200 C is difficult to restart after it is warmed up. I suspect it may need a new ignition module. I've never replaced one before so my question is this if anyone knows... The replacement part # is 32622-04. There is a revised part # 32622-04B AND 32622-04C. Would I just purchase the latest "C" part and plug it in?
Thank all for any replies.
19th June 2012
Sportster Fanatic
Posts: 487 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2003 Sportster/Buell Model #2: Buell Blast! Sportster/Buell Year #2: 2007
Originally Posted by Daali
It is fairly simple, but you will need to find tdc to adjust the timing. Once you pull the other module, you will place rhe new one in. It will be close to perfect without adjusting if you put it inthe exact spot, but i recommend going thru the timing procedure.
EDIT!! do not listen to me. I thought the 2005 was still a nosecone ignition, not the TC88A. My apologies
2007 Buell Blast: NRHS 515cc, NRHS Stage 2 head, NRHS Andrews B50 Cams, SE Ignition, Jardine RT-1, Dan's SuperBoot, Dan's Custom Intake, Glowshift Tach 7, Innovate Wideband o2 gauge, Jetted 45/175, CVP Emulsion Tube, CVP N65C Needle, SuperBike bars, SuperBrace, Currently breaking in new topend!
2003 XL1200C: Andrews N4 Cams[NRHS], Daytona Tech 1005, Samson Caliber 2 into 1, Pro-S Hypercharger, Daytona Tech 2005 coil, Speedway Instruments MicroTach, Jetted 45/180 NOKK, CVP Emulsion Tube, Drag Bars
19th June 2012
Posts: 79 Sportster/Buell Model: XL1200C Sportster/Buell Year: 04
Yes, you would use the latest rev "C" part, but I can probably think of a couple of dozen other items that I would check/replace first.
Maybe you could better describe "difficult to restart".
04 1200C - Bub Jug Huggers - NRHS Hurricane Flow A/C - Daytona TC88A Ignition
19th June 2012
Not applicable to an 05 1200.
19th June 2012
Sportster Fanatic
Ack!! Delete my post !! If bad info
19th June 2012
A Million Facts & Figures
Posts: 5,874 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
Difficulty starting warm seems highly unlikely to be caused by an ignition module to me. These ignitions are pretty darned rugged, and failures to be rare, but when they do, it's more an on/off thing. Or on your bike, it's more likely to be a crank position sensor than the module, the cps is known to be troublesome that year.
If you'd like a new module, though, I'd highly recommend a Twin Tec TC88A. Your bike, being an '05, has no method by which to adjust the timing. A module like the TC88A gives you that capability.
For hard starting warm, I'd look more to something related to fueling. Rich mixtures can cause this. Put it on a dyno with an a/f sniffer if possible. Look at your plugs. Check compression. Lots of better places to look than your ignition module.
19th June 2012
Posts: 5,620 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
You do not need a new ignition module.
You should post your symptoms so the experts can tell you how to diagnose the problem.
Just tossing money blindly at problems usually ends with an empty wallet and the problem still exists.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
19th June 2012
Thanks for the quick response! I find after it is warmed up is stongly turns over but almost acts as though its not getting enough fuel to start right away
19th June 2012
This year replaced battery, spark plugs and wires and negative cable and ckp last year. Its just a recent issue but the bike is running rich.
19th June 2012
How long has it been shut off when you try to restart it?
Even on a hot summer day, if I shut down for 30-40 minutes, the bike needs the enrichner (choke) pulled out 1/2 way and a couple of twists on the throttle before hitting the start button, to get it to fire right off on the first or second revolution.
| Thread Tools |
| Display Modes |
