Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Tanjis Kahn, george (58), mwndragon (56), XxValDeexX (32), ELPYRO (31)
Ironworks Magazine
Speedway Instruments
NRHS Performance Long 2
Old 20th June 2012
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
Originally Posted by Neckkbone View Post
I think your petcock is fine. I think you probably hit the rev limiter.You didn't memtion any mods so I am assuming the bike is stock. Not quite sure of rev limit on a 1200R model though.
Uhhh... Didn't mention any mods? How about a CV44 for atarters? Then what mods does he have to be able to suck that much air into the engine?
Yes, I would put a pingle on it regardless if that is the current problem or not. Fuel delivery is a problem with lots of vehicles that people modify to race with. We used to find guys at the circle track with cars still running the entire stock fuel line from the fuel cell forward, and they wondered why they couldn't tune the carburetor?
Fuel delivery is one of the first things that should be considered always.
Oh, I disagree with Pingle being overpriced. In my opinion, quality comes first, and in that respect they are priceless.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
Old 20th June 2012
flyboyJ flyboyJ is offline
Other Motorcycle Model: Yamaha XT 350
flyboyJ has disabled reputation
Thanks for all the input. And, yes, the bike perks right up when I let off the throttle and in all other situations.
I guess I'll go with the pingel, but first I'm going to try to pinch the vacuum line at idle so as to keep the valve open and hit the highway and see if that works.
I'll let you know, provided - of course - that I don't get arrested during 'testing'.
Cheers.
flyboyJ
Old 22nd June 2012
Neckkbone's Avatar
Neckkbone Neckkbone is offline
Sportster/Buell Model: 1200C Anniv. Edtn
Other Motorcycle Model: Night-Rod Sp. Ed.
Neckkbone has disabled reputation
WHOA!! Thought you were running stock 1200R. Also thiought 04-up were ALL efi (my bad). At 88 ci. fuel could be a problem!
The Only GOOD Martyr Is a DEAD Martyr!!
03 1200C, org. SE A/C, SE High Torque exhaust, SE .497 cams., SE tunable race ignition set @6000 rpm, 45 low, 180 high, Burly Slammer kit
Old 22nd June 2012
milmat1's Avatar
milmat1 milmat1 is offline
Known Troublemaker !
Sportster/Buell Year: 06
milmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant future
Cheers.
flyboyJ
Well guess we should we call the bail bondsman today.....
New to the Harley World, Some Good Info Here : NEW TO HARLEY'S
READING SPARK PLUGS: READING PLUGS
Check For Intake/Exhaust Leaks: CHECKING For Leaks
How to Check the Diaphragm! : Diaphragm_Test
REPLACING INTAKE/CARB SEALS:Replacing Intake Seals
MAINTENANCE INFO 04-06 : HANDY REFFERENCE
My futile attempt at Blogging: http://toolstolivewith.blogspot.com/
Old 22nd June 2012
rocketmangb's Avatar
Jester Mafia
Other Motorcycle Model: 48
rocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant future
You pinch that line at idle and as soon as it bleeds off you are out of fuel
Actually at 125 in 5 th the vacuum should be coming back I think !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
Old 22nd June 2012
wedge's Avatar
Whitworth Products
2 days... I sure hope it's just a bail bond that he needs. Lets face it, pushing these things over 100 is always a bit on the shaky side unless you have cartridge forks and some good shocks in the back too, and another degree on the front end wouldn't hurt either.
By the way, Works has cartridges for these forks right now for $399.00 which is cheaper than Works springs with Intiminators and logically much better. Plus I have it from a direct source that Progressive will have cartridges for the sporty within a couple of months. (Just some interesting info that I thought everyone would like to know).
Old 1st February 2013
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
what fixed it?
Link to thread on "Harley Racing" events across the country: http://xlforum.net/vbportal/forums/showthread.php?t=53470
Old 2nd February 2013
Default The Fix
It was a venting issue. I removed the one-way valve that clips to the left side, under the battery cover. That cured it.
I can't recall now as to whether I bought a new valve - it's winter here - but I believe I did.
I've never found the need for a Pingel myself. Plus, even though I routinely shut off my stock fuel valve, sometimes I forget. I'd always worry, with a Pingel, that if some grit or something prevented the float-bowl from returning to the proper position and I forgot to turn it to 'off', I could end up with the cylinders getting a wash down with fuel.
flyboyJ
