Get Lowered
Biltwell
Speedway Instruments
Foxcreek Leather
Biltwell
Old 22nd June 2012
sportsterxlch sportsterxlch is offline
Sportster/Buell Year: 1969
sportsterxlch is an unknown quantity at this point
Default Oil Line Fittings Question
I bought new oil line fittings for my 69' xlch. Two of them have small holes and the other two have large holes. Can anyone tell me which set goes into the rocker boxes, and which go into the crankcase? Thanks*
Old 22nd June 2012
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
khaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud of
Moved to the IronHead section. You'll get the correct answer here.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 22nd June 2012
Monte03's Avatar
Monte03 Monte03 is online now
Other Motorcycle Year: 82
Monte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the roughMonte03 is a jewel in the rough
Default Oil Lines
If you are talking about the Skinny Lines feeding the Rocker Boxes they are the same size on both sides, 1/8" male pipe X compression, unless along the way some one oversided the hole?
Pictures needed here....
Cycle World Oct 1962:
Old 22nd June 2012
heavy.clutch's Avatar
heavy.clutch heavy.clutch is offline
Sportster/Buell Year: 1976
heavy.clutch is an unknown quantity at this point
I would put large hole on fitting at the top and smaller hole on the fitting on the bottom this will stop oil pipe from dropping into case.
