The Sportster and Buell Motorcycle Forum Get Lowered Sportster
Marks Moto Gear
CV Performance
Progressive Suspension
Old 30th July 2012
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
It will do that to cloth, and it seems from your observation that it will do it to leather too, but not to rubber. It's a good idea to get some baking soda and mix it with water (lots of baking soda), and brush it around there, pour it, or spray it in the area. It will fizz up good where there is still acid. Good for the cable ends on the battery too. Then rinse it off and forget about it. Make sure the battery is closed when you do it, because you don't want any inside the battery.
+1 on baking soda and water in a jar to clean battery cables I do that when I put a new battery in a bike or 4 wheeler. Nikki
the difficult can be done immediatey the impossible takes a little longer
Old 30th July 2012
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
Yeah, that's not acid related, but definitely a good catch. It's time for a chain. How long has that been on the bike? General rule of thumb is to change BOTH sprockets when you swap the chain.
Look at the rear sprocket and see if it is fish hooking on the back side of the teeth. (Where the chain pulls against the sprocket). Any sign of elongating of the sprocket grip area or fish hooking and it has to be done now. If not you can maybe get away with just a chain for a bit, however; a new chain on old sprockets just kills the chain really fast, so buy a cheap non O-ring chain for temporary if you choose that route.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
Old 30th July 2012
ezmerf's Avatar
ezmerf ezmerf is offline
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
BTW good catch on that chain you should see what one can do to your cases when they ball up on frt sprocket.
Murphy's Law
