Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Marks Moto Gear
Progressive Suspension
Dead Creek Cycles
NRHS
Old 13th August 2012
sporty74 sporty74 is offline
sporty74 is an unknown quantity at this point
Default over oiling
I need some help> im kinda new working on the ironhead. bought a 74 sportster XLCH a month ago thats been sitting for 15 years. freshened it up with new everything!!! exept the motor. its untouched. go it ridable new oil-the whole works all oil levels correct. 10 miles primary/trans very low and oil tank over full? so drained tank to proper level filled trans. and 10-15 miles later.....same thing??? any 1 with idias? thank you.
sportsterpaul sportsterpaul is online now
Other Motorcycle Model: XLH
Other Motorcycle Year: 1972
Crankshaft seal may be allowing cross contamination, but it usually works in the reverse. I haven't gotten into my '72 I.H. yet, (been under a blanket since '89, so I'm not well versed on them.
I.B.A.#26543, Old age and treachery ALWAYS overcome youth and skill! ******** Growing old-Mandatory/ Growing up-optional. Men do not quit playing because they get old, they grow old because they quit playing
ok.... im ton sure if i should pull enine and do a total rebuild???
We have and excellant group of Ironhead riders that know every nook and cranny of I.H.'s, they'll be along shortly, be patient. When I pull the blanket off mine it will be comforting to know the skills and experiences they have shared, and I know they will be a big help for me.
Post
I have leaned a lot so far but not nearly enough! im an auto tech by day and rookie bike builder at night. dont understand how the trans wud push oil to engine side?? unless the oil pump pulls il threw a bad seal. rely dont want to pull the engine apart without some knowledge of wats going on. i feel its soon to come. thanks again.
That was my thought exactly,usually its a crankseal failure and the crankcase pressure pushes engine oil out to the primary cavity.
Old 14th August 2012
tmack-1's Avatar
tmack-1 tmack-1 is offline
Sportster/Buell Model: Sportster XLH1100
Sportster/Buell Year: 1986
Other Motorcycle Model: Rupp Roadster
Other Motorcycle Year: 1971
tmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nicetmack-1 is just really nice
If the tranny vent is plugged (dirt, bugs, etc etc) the tranny can build up presure from the air expanding when it gets warm. (trust me, I pinched the hose they used on the '86's under the seat when I put the seat back on.....)
I'm not saying that's your problem, but it may be someplace to start at.
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
Old 16th August 2012
MN Mailman's Avatar
MN Mailman MN Mailman is offline
Sportster/Buell Model: AMF XLS Roadster
Sportster/Buell Year: 1981
MN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of light
Default Post this in the ironhead section......
.........and your problems will be solved.
Sounds like a check valve is fubared.
Question Authority
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Hopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to beholdHopper is a splendid one to behold
Could be sprocket shaft seal.
Could be oil transfer valve (between primary and crankcase).
Both those are easy to fix. More info on the oil transfer valve over in the Ironhead section.
If you post future queries in the Ironhead section you will get more response.
