15th September 2012
Posts: 23,710 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
I think you cannot use the early type, like 1972, that requires removal of the primary cover to do the adjust. You can use either of the two types of spring shown in the parts catalog 994561-85A page 60 - the flat spring metal in the pic above [40019-77] or the wire spring with the two coils [40019-80A].
15th September 2012
Posts: 2,450 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
Originally Posted by 72 Ironhead XLH
can you use the style in the 1972 type.
'77 was first year of true left side shift with pegs etc coming out of the primary, i don't think the left case half has the correct bosses with the two bolt holes for that type of chain adjuster. that's a '76 - down thing.
steal your face right off your head!
15th September 2012
Posts: 2,275 Sportster/Buell Model: xls roadster Sportster/Buell Year: 1982
doodah man and Mick are right 77 to 85 iron head primary cases do not have the bosses for the 76 and down chain adjuster. Nikki
the difficult can be done immediatey the impossible takes a little longer
15th September 2012
Posts: 974 Sportster/Buell Model: xlh 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: XLCH 1000 Sportster/Buell Year #2: 1979
I wouldn't risk busting the cases, weld that sucker up, redrill and tap. the plastic shoe is a $5 part, part # 40019-77 shouldn't cost much either.
I'm not a complete idiot, some parts are missing.
15th September 2012
Posts: 178 Sportster/Buell Model: XLH Sportster/Buell Year: 1977
Originally Posted by brucstoudt
i,think the weld repair can be done with the motor in the frame.as long as you remove the gas tank,and carb,and drain the oil.
Ok welder has been booked. What else has to be done to weld this sucker still in frame. brucstoudt mentioned draining the oil. I'm assuming that means the dreaded crankcase drainplug. Gas tank and carb aren't an issue to break down.
Can't seem to find any details on pulling the motor sprocket in the FSM so i'm assuming it's straight forward.
Anything else?
I'm just a newb with an ironhead, a toolbox, a computer and a FSM.
15th September 2012
Posts: 5,130 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
no!!!,just drain the oil out of the tank,so it does'nt spill. leave that drain plug in place. does the welder know the motor is in the frame,and has to be laid on it's side.
15th September 2012
i,use a 2,jaw puller to remove my motor sprocket. some model's have threaded hole's in the sprocket to pull with.
15th September 2012
Originally Posted by jhaines
... Can't seem to find any details on pulling the motor sprocket in the FSM so i'm assuming it's straight forward ...
Remove primary chain, motor sprocket and clutch assemblies all together. Motor sprocket nut will require a 5' steel pipe extension or an impact wrench; the latter probably being a better choice.
15th September 2012
HAHAHAHAHA ok
15th September 2012
Taking the risk of basking in all of my newb gloriousness...
How can this get pulled all together.
I'm looking at the FSM and can't seem to figure out how to pull the clutch whole
| Thread Tools |
| Display Modes |
